[postgis-devel] [postgis-tickets] r16128 - Doco on "enhancement" per robe, closes #3097
Sandro Santilli strk at kbt.io
Thu Nov 30 23:57:51 PST 2017
On Thu, Nov 30, 2017 at 05:15:47PM -0500, Regina Obe wrote:
> Changed:  You might want to check your existing code to make sure it behaves
> as expected
> Enhanced: Provided new functionality in an existing function
So the previous line should also read "Enhanced", right ? Was anohter
case of adding new support. We should try to be consistent there:
> --- trunk/doc/reference_processing.xml        2017-11-30 19:18:03 UTC (rev 16127)
> +++ trunk/doc/reference_processing.xml        2017-11-30 20:52:56 UTC (rev 16128)
> @@ -3084,6 +3084,8 @@
>              <para>Availability: 2.0.0</para>
>              <para>Changed: 2.2.0 support for splitting a line by a multiline, a multipoint or
(multi)polygon boundary was introduced.</para>
> +             <para>Enhanced: 2.5.0 support for MULTILINESTRING split blades.</para>
--strk;
