[postgis-devel] RFC6 - Drop GEOS C++ API at GEOS 3.8
Mateusz Loskot
mateusz at loskot.net
Mon Oct 2 00:13:05 PDT 2017
-1 (as used-to-be-PSC)
> As Bas said already it causes packagers headaches.
So, the solution is to take the toys away from the kids...
Regards,
Mateusz
On 2 October 2017 at 04:49, Regina Obe <lr at pcorp.us> wrote:
> Okay I have created an RFC6 to officially drop GEOS C++ starting at GEOS 3.8 (so as soon as we release GEOS 3.7 (which should be next month), and flip the switch, we drop the C++ headers as well so developers won't be tempted to use them.
> https://trac.osgeo.org/geos/wiki/RFC6
> As Bas said already it causes packagers headaches. It causes PostGIS headaches because users can't easily migrate to newer versions of GEOS because the packages they rely on e.g osm2pgsql (which is going away because we broke ABI with C++ aPI between 3.5 and 3.6).
> If we can't support something, let's not provide it period. It's disservice to everybody.
> I know Sandro you think making it noisy would solve the issue. Trust me it won't. There is so much noise with all dependencies people compile with that most developers are trained to ignore them.
> The proof to them is it compiles and passes their tests. Unless of course you plan to introduce noise in production build, which makes GEOS useless anyway.
> It is my understanding that only osm2pgsql (which is dropping GEOS anyway) and osmium which has already dropped GEOS, were the only big projects using the C++ API. Lets not leave it in as that will just leave the whole open for newer projects to start using it.
> As GEOS PSC member I vote +1 for dropping GEOS C++ API.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Mateusz Loskot, http://mateusz.loskot.net
