[postgis-devel] change suggestion to a wiki page
G. Allegri
giohappy at gmail.com
Mon Oct 30 13:24:31 PDT 2017
I posted this to postgis-users but probably it's better here.
Reading the suggested SQL in
https://trac.osgeo.org/postgis/wiki/UsersWikiSimplifyWithTopologyExt to
generate the simplified edges geoms I think a minor change would provide
more robust results
In Phase 3:
>select ST_Collect(st_simplifyPreserveTopology(geom, 10000)) as geom
could be canged to:
>select ST_SimplifyPreserveTopology(ST_Collect(geom), 10000)) as geom
This guarantees that topology is preserved between edge_data geometries.
This solved various issues I obtained while applying the original SQL to
some intricated geometries.
If you agree on this I can modify the wiki page directly (is it allowed to
registered members?).
All the best,
giovanni
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171030/d40e94fe/attachment.html>
