[postgis-devel] [postgis-tickets] r15732 - Add check-no-trailing-blanks Makefile rule and run on `make check`
Sandro Santilli strk at kbt.io
Sat Sep 16 01:37:48 PDT 2017
On Thu, Sep 14, 2017 at 12:30:18PM -0400, Daniel Baston wrote:
> Should this check .c, instead of .cpp ?
Ouch, that's why it succeeded so easily ! :)
So it looks like we have 2818 lines to be changed to make the
correct test pass. Do you think I should proceed ?
--strk;
