[postgis-devel] different result ST_Tesselate from invalid polygon that ST_IsValid says is valid
Nicklas Avén
nicklas.aven at jordogskog.no
Tue Apr 24 11:48:29 PDT 2018
Hello
I have an ugly polygon, presented as wkt here below.
It is really ugly, and from what I understand it has selfintersection
and other things taht I expected ST_Isvalid to react on.
But ST_Isvalid let's it through.
And on 2 of my PostGIS installations ST_Tesselate gives a reasonable
answer. But on a third installation on a virtual machine at Linode I
get an error message which I am not sure where it comes from. It says:
ERROR: Polygon is invalid : interior is not connected
Does that come from boost?
So this is 2 questions:
1) Why doesn't ST_Isvalid tell me it is invalid
2) Where should I search for the different results?
As far as I can find I have the exactly same versions on everything on
the installs.
POSTGIS="2.5.0dev r16554" [EXTENSION] PGSQL="100" GEOS="3.7.0dev-CAPI-
1.11.0 r" SFCGAL="1.3.0" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL
2.1.2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1" RASTER
(1 row)
and boost version seems to be the same
Package: libboost-system1.62.0
Could someone else with sfcgal enabled see what result they get?
select st_tesselate(
'POLYGON((389923 6365025,390094 6364730,390269 6364430,390261
6364415,390250 6364399,390239 6364372,390207 6364367,390168
6364372,390136 6364377,390100 6364393,390081 6364429,390070
6364458,390059 6364474,390059 6364494,390044 6364497,390019
6364506,390012 6364512,389985 6364533,389973 6364545,389951
6364567,389931 6364588,389927 6364598,389912 6364628,389907
6364636,389883 6364647,389870 6364649,389863 6364638,389858
6364613,389851 6364591,389817 6364575,389795 6364594,389792
6364625,389791 6364653,389796 6364679,389802 6364695,389811
6364722,389840 6364741,389868 6364741,389882 6364721,389900
6364705,389915 6364699,389915 6364717,389909 6364737,389891
6364770,389885 6364781,389867 6364798,389845 6364810,389823
6364809,389801 6364815,389778 6364822,389761 6364822,389742
6364840,389732 6364863,389741 6364890,389741 6364919,389744
6364920,389760 6364932,389768 6364940,389774 6364954,389776
6364963,389787 6364970,389816 6364981,389852 6364993,389895
6365011,389923 6365025),(390094 6364730,389987 6364914,389981
6364904,389971 6364887,389947 6364869,389921 6364853,389895
6364832,389892 6364816,389906 6364812,389941 6364818,389973
6364827,390021 6364852,390094 6364730),(390094 6364730,390050
6364714,390050 6364713,390094 6364730),(390050 6364714,390034
6364736,390014 6364733,389982 6364724,389954 6364721,389953
6364710,389958 6364695,389964 6364677,389972 6364672,389988
6364673,390015 6364678,390041 6364695,390049 6364713,390047
6364713,390050 6364714))'::geometry);
Thanks
Nicklas
