[postgis-devel] Bumping dependencies versions for PostGIS 3.0
Darafei "Komяpa" Praliaskouski me at komzpa.net
Tue Dec 4 02:33:51 PST 2018
Thanks.
I cleaned up < Postgres 9.5 code in trunk:
https://github.com/postgis/postgis/commit/06eebf5bc3a7bd36cb0ada3ea6512856073999f2
Created a ticket to bump:
https://trac.osgeo.org/postgis/ticket/4268 SFCGAL to 1.3.1.
https://trac.osgeo.org/postgis/ticket/4267 GEOS to 3.6.
On Sun, Dec 2, 2018 at 8:34 PM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 12/2/18 6:10 PM, Regina Obe wrote:
> > The BSDs I think are all around 3.6, and FWIW on the Bessies they are
> > running 3.6 which is latest stable.
> FreeBSD has 3.6.3, see:
>  https://svnweb.freebsd.org/ports/head/graphics/geos/
> OpenBSD has 3.7.0, see:
>  http://cvsweb.openbsd.org/cgi-bin/cvsweb/ports/geo/geos/
> NetBSD has 3.7.1, see:
>  http://pkgsrc.se/geography/geos
> > Macs I have no clue what they do – seems all over the place.
> MacPorts has 3.7.0, see:
>  https://github.com/macports/macports-ports/tree/master/science/geos
> Homebrew has 3.7.0, see:
>  https://formulae.brew.sh/formula/geos
> > Trusty is on its last legs so not too concerned about that and it was
> > already screwed with our 3.5 upgrade on 2.5 anyway. Xenial I'm a
> > little concerned about (and I think the reason we didn't bump to 3.6
> > in 2.5), but probably when we swing out 3.7, xenial will be on its
> > last legs as well so of low concern. That would still leave bionic and
> > cosmic stuck on 3.6, which we don't want to screw.
> trusty is supported until April 2019.
> xenial is supported until April 2021.
> bionic is supported until April 2023.
> trusty is really showing its age, many recent releases of projects have
> issues with its outdated packages. I also wouldn't worry too much about it.
> xenial also lacks some things, but is not as bad as trusty.
> Everyone who want to build recent releases on Ubuntu LTS should be using
> bionic.
> I also wouldn't worry about non-LTS releases, as they are only supported
>  for less than a year.
> Kind Regards,
> Bas
>  GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181204/4261b32c/attachment.html>
