[postgis-devel] Bumping dependencies versions for PostGIS 3.0
Sebastiaan Couwenberg
sebastic at xs4all.nl
Sun Dec 2 09:34:45 PST 2018
On 12/2/18 6:10 PM, Regina Obe wrote:
> The BSDs I think are all around 3.6, and FWIW on the Bessies they are
> running 3.6 which is latest stable.
FreeBSD has 3.6.3, see:
https://svnweb.freebsd.org/ports/head/graphics/geos/
OpenBSD has 3.7.0, see:
http://cvsweb.openbsd.org/cgi-bin/cvsweb/ports/geo/geos/
NetBSD has 3.7.1, see:
http://pkgsrc.se/geography/geos
> Macs I have no clue what they do – seems all over the place.
MacPorts has 3.7.0, see:
https://github.com/macports/macports-ports/tree/master/science/geos
Homebrew has 3.7.0, see:
https://formulae.brew.sh/formula/geos
> Trusty is on its last legs so not too concerned about that and it was
> already screwed with our 3.5 upgrade on 2.5 anyway. Xenial I'm a
> little concerned about (and I think the reason we didn't bump to 3.6
> in 2.5), but probably when we swing out 3.7, xenial will be on its
> last legs as well so of low concern. That would still leave bionic and
> cosmic stuck on 3.6, which we don't want to screw.
trusty is supported until April 2019.
xenial is supported until April 2021.
bionic is supported until April 2023.
trusty is really showing its age, many recent releases of projects have
issues with its outdated packages. I also wouldn't worry too much about it.
xenial also lacks some things, but is not as bad as trusty.
Everyone who want to build recent releases on Ubuntu LTS should be using
bionic.
I also wouldn't worry about non-LTS releases, as they are only supported
for less than a year.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
