[postgis-devel] PATH required on make check
Bruce Rindahl bruce.rindahl at gmail.com
Mon Dec 17 20:30:54 PST 2018
Running make check with no special path requirements runs fine on several
tests until the raster tests.  All tests until then appends
/use/local/pgsql/bin to the path ( from --with-pgconfig parameter??)
but it does not append it on the raster tests.  Need documentation or
consistency?
Thanks
Bruce
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181217/453da9d5/attachment.html>
