[postgis-devel] PATH required on make check
Darafei "Komяpa" Praliaskouski me at komzpa.net
Tue Dec 18 02:57:59 PST 2018
Hi Bruce,
Can you please provide a step by step way to reproduce?
вт, 18 дек. 2018 г. в 07:31, Bruce Rindahl <bruce.rindahl at gmail.com>:
> Running make check with no special path requirements runs fine on several
> tests until the raster tests.  All tests until then appends
> /use/local/pgsql/bin to the path ( from --with-pgconfig parameter??)
> but it does not append it on the raster tests.  Need documentation or
> consistency?
> Thanks
> Bruce
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181218/ea8e2ed3/attachment.html>
