[postgis-devel] PATH required on make check
Bruce Rindahl bruce.rindahl at gmail.com
Tue Dec 18 03:36:23 PST 2018
/usr/local/pgsql/bin is not in PATH
Then in source:
./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config
make
sudo make install
make check
The first few sets of checks run (PATH is shown as including
).  When you get to the raster tests, PATH does not show /usr/local/pgsql/bin
and the tests fail.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181218/fc3b36d7/attachment.html>
