[postgis-devel] [postgis-tickets] r16409 - Format lwgeom_geos_clean.c before digging in
Daniel Baston
dbaston at gmail.com
Thu Feb 22 08:18:02 PST 2018
Why are you doing this? Was there a discussion to switch the code base to
a new style?
Dan
On Thu, Feb 22, 2018 at 10:52 AM, Darafei <komzpa at gmail.com> wrote:
> Author: komzpa
> Date: 2018-02-22 07:52:47 -0800 (Thu, 22 Feb 2018)
> New Revision: 16409
> Modified:
> trunk/liblwgeom/lwgeom_geos_clean.c
> Log:
> References #2508
> Modified: trunk/liblwgeom/lwgeom_geos_clean.c
> --- trunk/liblwgeom/lwgeom_geos_clean.c 2018-02-22 13:42:00 UTC (rev
> 16408)
> +++ trunk/liblwgeom/lwgeom_geos_clean.c 2018-02-22 15:52:47 UTC (rev
> 16409)
> @@ -22,7 +22,6 @@
> #include "liblwgeom.h"
> #include "lwgeom_geos.h"
> #include "liblwgeom_internal.h"
> @@ -36,7 +35,6 @@
> /* #define PARANOIA_LEVEL 2 */
> #undef LWGEOM_PROFILE_MAKEVALID
> * Return Nth vertex in GEOSGeometry as a POINT.
> * May return NULL if the geometry has NO vertexex.
> @@ -53,7 +51,7 @@
> int gn;
> GEOSGeometry* ret;
> - switch ( GEOSGeomTypeId(g_in) )
> + switch (GEOSGeomTypeId(g_in))
> case GEOS_MULTIPOINT:
> case GEOS_MULTILINESTRING:
> @@ -60,11 +58,11 @@
> case GEOS_MULTIPOLYGON:
> case GEOS_GEOMETRYCOLLECTION:
> - for (gn=0; gn<GEOSGetNumGeometries(g_in); ++gn)
> + for (gn = 0; gn < GEOSGetNumGeometries(g_in); ++gn)
> const GEOSGeometry* g = GEOSGetGeometryN(g_in, gn);
> - ret = LWGEOM_GEOS_getPointN(g,n);
> - if ( ret ) return ret;
> + ret = LWGEOM_GEOS_getPointN(g, n);
> + if (ret) return ret;
> break;
> @@ -72,12 +70,12 @@
> case GEOS_POLYGON:
> ret = LWGEOM_GEOS_getPointN(GEOSGetExteriorRing(g_in), n);
> - for (gn=0; gn<GEOSGetNumInteriorRings(g_in); ++gn)
> + for (gn = 0; gn < GEOSGetNumInteriorRings(g_in); ++gn)
> const GEOSGeometry* g = GEOSGetInteriorRingN(g_in,
> gn);
> break;
> @@ -86,37 +84,34 @@
> case GEOS_LINESTRING:
> case GEOS_LINEARRING:
> break;
> seq_in = GEOSGeom_getCoordSeq(g_in);
> - if ( ! seq_in ) return NULL;
> - if ( ! GEOSCoordSeq_getSize(seq_in, &sz) ) return NULL;
> - if ( ! sz ) return NULL;
> + if (!seq_in) return NULL;
> + if (!GEOSCoordSeq_getSize(seq_in, &sz)) return NULL;
> + if (!sz) return NULL;
> - if ( ! GEOSCoordSeq_getDimensions(seq_in, &dims) ) return NULL;
> + if (!GEOSCoordSeq_getDimensions(seq_in, &dims)) return NULL;
> seq_out = GEOSCoordSeq_create(1, dims);
> - if ( ! seq_out ) return NULL;
> + if (!seq_out) return NULL;
> - if ( ! GEOSCoordSeq_getX(seq_in, n, &val) ) return NULL;
> - if ( ! GEOSCoordSeq_setX(seq_out, n, val) ) return NULL;
> - if ( ! GEOSCoordSeq_getY(seq_in, n, &val) ) return NULL;
> - if ( ! GEOSCoordSeq_setY(seq_out, n, val) ) return NULL;
> - if ( dims > 2 )
> + if (!GEOSCoordSeq_getX(seq_in, n, &val)) return NULL;
> + if (!GEOSCoordSeq_setX(seq_out, n, val)) return NULL;
> + if (!GEOSCoordSeq_getY(seq_in, n, &val)) return NULL;
> + if (!GEOSCoordSeq_setY(seq_out, n, val)) return NULL;
> + if (dims > 2)
> - if ( ! GEOSCoordSeq_getZ(seq_in, n, &val) ) return NULL;
> - if ( ! GEOSCoordSeq_setZ(seq_out, n, val) ) return NULL;
> + if (!GEOSCoordSeq_getZ(seq_in, n, &val)) return NULL;
> + if (!GEOSCoordSeq_setZ(seq_out, n, val)) return NULL;
> return GEOSGeom_createPoint(seq_out);
> -LWGEOM * lwcollection_make_geos_friendly(LWCOLLECTION *g);
> -LWGEOM * lwline_make_geos_friendly(LWLINE *line);
> -LWGEOM * lwpoly_make_geos_friendly(LWPOLY *poly);
> +LWGEOM* lwcollection_make_geos_friendly(LWCOLLECTION* g);
> +LWGEOM* lwline_make_geos_friendly(LWLINE* line);
> +LWGEOM* lwpoly_make_geos_friendly(LWPOLY* poly);
> POINTARRAY* ring_make_geos_friendly(POINTARRAY* ring);
> @@ -125,8 +120,8 @@
> * May return the input untouched (if already valid).
> * May return geometries of lower dimension (on collapses)
> -static LWGEOM *
> -lwgeom_make_geos_friendly(LWGEOM *geom)
> +static LWGEOM*
> +lwgeom_make_geos_friendly(LWGEOM* geom)
> LWDEBUGF(2, "lwgeom_make_geos_friendly enter (type %d)",
> geom->type);
> switch (geom->type)
> @@ -139,18 +134,18 @@
> case LINETYPE:
> /* lines need at least 2 points */
> - return lwline_make_geos_friendly((LWLINE *)geom);
> + return lwline_make_geos_friendly((LWLINE*)geom);
> break;
> case POLYGONTYPE:
> /* polygons need all rings closed and with npoints > 3 */
> - return lwpoly_make_geos_friendly((LWPOLY *)geom);
> + return lwpoly_make_geos_friendly((LWPOLY*)geom);
> break;
> case MULTILINETYPE:
> case MULTIPOLYGONTYPE:
> case COLLECTIONTYPE:
> - return lwcollection_make_geos_friendly((LWCOLLECTION
> *)geom);
> + return lwcollection_make_geos_
> friendly((LWCOLLECTION*)geom);
> break;
> case CIRCSTRINGTYPE:
> @@ -159,7 +154,9 @@
> case MULTISURFACETYPE:
> case MULTICURVETYPE:
> default:
> - lwerror("lwgeom_make_geos_friendly: unsupported input
> geometry type: %s (%d)", lwtype_name(geom->type), geom->type);
> + lwerror("lwgeom_make_geos_friendly: unsupported input
> + lwtype_name(geom->type),
> + geom->type);
> break;
> return 0;
> @@ -178,13 +175,10 @@
> POINTARRAY* newring;
> /* close the ring if not already closed (2d only) */
> - if ( ! ptarray_is_closed_2d(ring) )
> + if (!ptarray_is_closed_2d(ring))
> /* close it up */
> - newring = ptarray_addPoint(ring,
> - getPoint_internal(ring, 0),
> - FLAGS_NDIMS(ring->flags),
> - ring->npoints);
> + newring = ptarray_addPoint(ring, getPoint_internal(ring,
> 0), FLAGS_NDIMS(ring->flags), ring->npoints);
> ring = newring;
> return ring;
> @@ -199,26 +193,19 @@
> closedring = ptarray_close2d(ring);
> - if (closedring != ring )
> - ring = closedring;
> + if (closedring != ring) ring = closedring;
> /* return 0 for collapsed ring (after closeup) */
> - while ( ring->npoints < 4 )
> + while (ring->npoints < 4)
> - POINTARRAY *oring = ring;
> + POINTARRAY* oring = ring;
> LWDEBUGF(4, "ring has %d points, adding another",
> ring->npoints);
> /* let's add another... */
> - ring = ptarray_addPoint(ring,
> - ring->npoints);
> - if ( oring != ring_in ) ptarray_free(oring);
> + ring = ptarray_addPoint(ring, getPoint_internal(ring, 0),
> + if (oring != ring_in) ptarray_free(oring);
> return ring;
> @@ -225,36 +212,35 @@
> /* Make sure all rings are closed and have > 3 points.
> * May return the input untouched.
> -LWGEOM *
> -lwpoly_make_geos_friendly(LWPOLY *poly)
> +LWGEOM*
> +lwpoly_make_geos_friendly(LWPOLY* poly)
> LWGEOM* ret;
> - POINTARRAY **new_rings;
> + POINTARRAY** new_rings;
> uint32_t i;
> /* If the polygon has no rings there's nothing to do */
> - if ( ! poly->nrings ) return (LWGEOM*)poly;
> + if (!poly->nrings) return (LWGEOM*)poly;
> /* Allocate enough pointers for all rings */
> - new_rings = lwalloc(sizeof(POINTARRAY*)*poly->nrings);
> + new_rings = lwalloc(sizeof(POINTARRAY*) * poly->nrings);
> /* All rings must be closed and have > 3 points */
> - for (i=0; i<poly->nrings; i++)
> + for (i = 0; i < poly->nrings; i++)
> POINTARRAY* ring_in = poly->rings[i];
> POINTARRAY* ring_out = ring_make_geos_friendly(ring_in);
> - if ( ring_in != ring_out )
> + if (ring_in != ring_out)
> - LWDEBUGF(3, "lwpoly_make_geos_friendly: ring %d
> cleaned, now has %d points", i, ring_out->npoints);
> + LWDEBUGF(
> + 3, "lwpoly_make_geos_friendly: ring %d
> ptarray_free(ring_in);
> else
> untouched", i);
> - assert ( ring_out );
> + assert(ring_out);
> new_rings[i] = ring_out;
> @@ -266,10 +252,10 @@
> /* Need NO or >1 points. Duplicate first if only one. */
> -LWGEOM *
> -lwline_make_geos_friendly(LWLINE *line)
> +LWGEOM*
> +lwline_make_geos_friendly(LWLINE* line)
> - LWGEOM *ret;
> + LWGEOM* ret;
> if (line->points->npoints == 1) /* 0 is fine, 2 is fine */
> @@ -276,9 +262,9 @@
> #if 1
> /* Duplicate point */
> line->points = ptarray_addPoint(line->points,
> - getPoint_internal(line->points,
> 0),
> - FLAGS_NDIMS(line->points->
> flags),
> - line->points->npoints);
> + getPoint_internal(line->points,
> 0),
> + FLAGS_NDIMS(line->points->
> flags),
> + line->points->npoints);
> ret = (LWGEOM*)line;
> #else
> /* Turn into a point */
> @@ -293,38 +279,36 @@
> -LWGEOM *
> -lwcollection_make_geos_friendly(LWCOLLECTION *g)
> +LWGEOM*
> +lwcollection_make_geos_friendly(LWCOLLECTION* g)
> - LWGEOM **new_geoms;
> - uint32_t i, new_ngeoms=0;
> - LWCOLLECTION *ret;
> + LWGEOM** new_geoms;
> + uint32_t i, new_ngeoms = 0;
> + LWCOLLECTION* ret;
> /* enough space for all components */
> - new_geoms = lwalloc(sizeof(LWGEOM *)*g->ngeoms);
> + new_geoms = lwalloc(sizeof(LWGEOM*) * g->ngeoms);
> ret = lwalloc(sizeof(LWCOLLECTION));
> memcpy(ret, g, sizeof(LWCOLLECTION));
> - ret->maxgeoms = g->ngeoms;
> + ret->maxgeoms = g->ngeoms;
> - for (i=0; i<g->ngeoms; i++)
> + for (i = 0; i < g->ngeoms; i++)
> LWGEOM* newg = lwgeom_make_geos_friendly(g->geoms[i]);
> - if ( newg ) new_geoms[new_ngeoms++] = newg;
> + if (newg) new_geoms[new_ngeoms++] = newg;
> ret->bbox = NULL; /* recompute later... */
> ret->ngeoms = new_ngeoms;
> - if ( new_ngeoms )
> + if (new_ngeoms)
> ret->geoms = new_geoms;
> else
> free(new_geoms);
> ret->geoms = NULL;
> - ret->maxgeoms = 0;
> + ret->maxgeoms = 0;
> return (LWGEOM*)ret;
> @@ -347,14 +331,12 @@
> point = LWGEOM_GEOS_getPointN(lines, 0);
> - if ( ! point ) return NULL;
> + if (!point) return NULL;
> - LWDEBUGF(3,
> - "Boundary point: %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(point, 0)));
> + LWDEBUGF(3, "Boundary point: %s", lwgeom_to_ewkt(GEOS2LWGEOM(point,
> 0)));
> noded = GEOSUnion(lines, point);
> - if ( NULL == noded )
> + if (NULL == noded)
> GEOSGeom_destroy(point);
> return NULL;
> @@ -363,9 +345,9 @@
> LWDEBUGF(3,
> - "LWGEOM_GEOS_nodeLines: in[%s] out[%s]",
> - lwgeom_to_ewkt(GEOS2LWGEOM(lines, 0)),
> - lwgeom_to_ewkt(GEOS2LWGEOM(noded, 0)));
> + "LWGEOM_GEOS_nodeLines: in[%s] out[%s]",
> + lwgeom_to_ewkt(GEOS2LWGEOM(lines, 0)),
> + lwgeom_to_ewkt(GEOS2LWGEOM(noded, 0)));
> return noded;
> @@ -381,31 +363,24 @@
> GEOSGeom gout;
> GEOSGeom geos_bound;
> GEOSGeom geos_cut_edges, geos_area, collapse_points;
> - GEOSGeometry *vgeoms[3]; /* One for area, one for cut-edges */
> - unsigned int nvgeoms=0;
> + GEOSGeometry* vgeoms[3]; /* One for area, one for cut-edges */
> + unsigned int nvgeoms = 0;
> - assert (GEOSGeomTypeId(gin) == GEOS_POLYGON ||
> - GEOSGeomTypeId(gin) == GEOS_MULTIPOLYGON);
> + assert(GEOSGeomTypeId(gin) == GEOS_POLYGON || GEOSGeomTypeId(gin)
> geos_bound = GEOSBoundary(gin);
> - if ( NULL == geos_bound )
> - return NULL;
> + if (NULL == geos_bound) return NULL;
> - LWDEBUGF(3,
> - "Boundaries: %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(geos_bound, 0)));
> + LWDEBUGF(3, "Boundaries: %s", lwgeom_to_ewkt(GEOS2LWGEOM(geos_bound,
> 0)));
> /* Use noded boundaries as initial "cut" edges */
> #ifdef LWGEOM_PROFILE_MAKEVALID
> - lwnotice("ST_MakeValid: noding lines");
> + lwnotice("ST_MakeValid: noding lines");
> #endif
> geos_cut_edges = LWGEOM_GEOS_nodeLines(geos_bound);
> - if ( NULL == geos_cut_edges )
> + if (NULL == geos_cut_edges)
> GEOSGeom_destroy(geos_bound);
> lwnotice("LWGEOM_GEOS_nodeLines(): %s",
> lwgeom_geos_errmsg);
> @@ -419,46 +394,40 @@
> GEOSGeometry* po;
> - lwnotice("ST_MakeValid: extracting unique points from bounds");
> + lwnotice("ST_MakeValid: extracting unique points from
> bounds");
> #endif
> pi = GEOSGeom_extractUniquePoints(geos_bound);
> - if ( NULL == pi )
> + if (NULL == pi)
> - lwnotice("GEOSGeom_extractUniquePoints(): %s",
> - lwgeom_geos_errmsg);
> + lwnotice("GEOSGeom_extractUniquePoints(): %s",
> return NULL;
> - LWDEBUGF(3,
> - "Boundaries input points %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(pi, 0)));
> + LWDEBUGF(3, "Boundaries input points %s",
> - lwnotice("ST_MakeValid: extracting unique points from cut_edges");
> cut_edges");
> #endif
> po = GEOSGeom_extractUniquePoints(geos_cut_edges);
> - if ( NULL == po )
> + if (NULL == po)
> GEOSGeom_destroy(pi);
> return NULL;
> - LWDEBUGF(3,
> - "Boundaries output points %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(po, 0)));
> + LWDEBUGF(3, "Boundaries output points %s",
> - lwnotice("ST_MakeValid: find collapse points");
> + lwnotice("ST_MakeValid: find collapse points");
> #endif
> collapse_points = GEOSDifference(pi, po);
> - if ( NULL == collapse_points )
> + if (NULL == collapse_points)
> @@ -467,12 +436,10 @@
> return NULL;
> - LWDEBUGF(3,
> - "Collapse points: %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(collapse_points,
> 0)));
> + LWDEBUGF(3, "Collapse points: %s",
> lwgeom_to_ewkt(GEOS2LWGEOM(collapse_points, 0)));
> - lwnotice("ST_MakeValid: cleanup(1)");
> + lwnotice("ST_MakeValid: cleanup(1)");
> #endif
> @@ -480,13 +447,11 @@
> - LWDEBUGF(3,
> - "Noded Boundaries: %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(geos_cut_edges, 0)));
> + LWDEBUGF(3, "Noded Boundaries: %s", lwgeom_to_ewkt(GEOS2LWGEOM(geos_cut_edges,
> 0)));
> /* And use an empty geometry as initial "area" */
> geos_area = GEOSGeom_createEmptyPolygon();
> - if ( ! geos_area )
> + if (!geos_area)
> lwnotice("GEOSGeom_createEmptyPolygon(): %s",
> GEOSGeom_destroy(geos_cut_edges);
> @@ -501,13 +466,13 @@
> while (GEOSGetNumGeometries(geos_cut_edges))
> - GEOSGeometry* new_area=0;
> - GEOSGeometry* new_area_bound=0;
> - GEOSGeometry* symdif=0;
> - GEOSGeometry* new_cut_edges=0;
> + GEOSGeometry* new_area = 0;
> + GEOSGeometry* new_area_bound = 0;
> + GEOSGeometry* symdif = 0;
> + GEOSGeometry* new_cut_edges = 0;
> - lwnotice("ST_MakeValid: building area from %d edges",
> GEOSGetNumGeometries(geos_cut_edges));
> + lwnotice("ST_MakeValid: building area from %d edges",
> #endif
> @@ -515,16 +480,15 @@
> new_area = LWGEOM_GEOS_buildArea(geos_cut_edges);
> - if ( ! new_area ) /* must be an exception */
> + if (!new_area) /* must be an exception */
> GEOSGeom_destroy(geos_area);
> - lwnotice("LWGEOM_GEOS_buildArea() threw an error:
> %s",
> + lwnotice("LWGEOM_GEOS_buildArea() threw an error:
> %s", lwgeom_geos_errmsg);
> return NULL;
> - if ( GEOSisEmpty(new_area) )
> + if (GEOSisEmpty(new_area))
> /* no more rings can be build with thes edges */
> GEOSGeom_destroy(new_area);
> @@ -536,7 +500,8 @@
> - lwnotice("ST_MakeValid: ring built with %d cut edges, saving
> boundaries", GEOSGetNumGeometries(geos_cut_edges));
> + lwnotice("ST_MakeValid: ring built with %d cut edges,
> saving boundaries",
> + GEOSGetNumGeometries(geos_cut_edges));
> #endif
> @@ -544,13 +509,13 @@
> * further cut edges later)
> new_area_bound = GEOSBoundary(new_area);
> - if ( ! new_area_bound )
> + if (!new_area_bound)
> /* We did check for empty area already so
> * this must be some other error */
> lwnotice("GEOSBoundary('%s') threw an error: %s",
> - lwgeom_to_ewkt(GEOS2LWGEOM(new_area, 0)),
> + lwgeom_to_ewkt(GEOS2LWGEOM(new_area, 0)),
> + lwgeom_geos_errmsg);
> return NULL;
> @@ -557,7 +522,7 @@
> - lwnotice("ST_MakeValid: running SymDifference with new area");
> + lwnotice("ST_MakeValid: running SymDifference with new
> area");
> #endif
> @@ -564,14 +529,13 @@
> * Now symdif new and old area
> symdif = GEOSSymDifference(geos_area, new_area);
> - if ( ! symdif ) /* must be an exception */
> + if (!symdif) /* must be an exception */
> GEOSGeom_destroy(new_area_bound);
> - lwnotice("GEOSSymDifference() threw an error: %s",
> + lwnotice("GEOSSymDifference() threw an error: %s",
> return NULL;
> @@ -592,19 +556,18 @@
> - lwnotice("ST_MakeValid: computing new cut_edges (GEOSDifference)");
> + lwnotice("ST_MakeValid: computing new cut_edges
> (GEOSDifference)");
> #endif
> new_cut_edges = GEOSDifference(geos_cut_edges,
> new_area_bound);
> - if ( ! new_cut_edges ) /* an exception ? */
> + if (!new_cut_edges) /* an exception ? */
> /* cleanup and throw */
> /* TODO: Shouldn't this be an lwerror ? */
> - lwnotice("GEOSDifference() threw an error: %s",
> + lwnotice("GEOSDifference() threw an error: %s",
> return NULL;
> @@ -612,37 +575,25 @@
> - lwnotice("ST_MakeValid: final checks");
> + lwnotice("ST_MakeValid: final checks");
> #endif
> - if ( ! GEOSisEmpty(geos_area) )
> + if (!GEOSisEmpty(geos_area))
> vgeoms[nvgeoms++] = geos_area;
> else
> - if ( ! GEOSisEmpty(geos_cut_edges) )
> + if (!GEOSisEmpty(geos_cut_edges))
> vgeoms[nvgeoms++] = geos_cut_edges;
> else
> - if ( ! GEOSisEmpty(collapse_points) )
> + if (!GEOSisEmpty(collapse_points))
> vgeoms[nvgeoms++] = collapse_points;
> else
> GEOSGeom_destroy(collapse_points);
> - if ( 1 == nvgeoms )
> + if (1 == nvgeoms)
> /* Return cut edges */
> gout = vgeoms[0];
> @@ -651,12 +602,11 @@
> /* Collect areas and lines (if any line) */
> gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
> vgeoms, nvgeoms);
> - if ( ! gout ) /* an exception again */
> + if (!gout) /* an exception again */
> - lwnotice("GEOSGeom_createCollection() threw an
> error: %s",
> + lwnotice("GEOSGeom_createCollection() threw an
> error: %s", lwgeom_geos_errmsg);
> /* TODO: cleanup! */
> return NULL;
> @@ -663,7 +613,6 @@
> return gout;
> static GEOSGeometry*
> @@ -679,44 +628,40 @@
> GEOSGeometry** lines;
> GEOSGeometry** points;
> - GEOSGeometry* mline_out=0;
> - GEOSGeometry* mpoint_out=0;
> - GEOSGeometry* gout=0;
> - uint32_t nlines=0, nlines_alloc;
> - uint32_t npoints=0;
> - uint32_t ngeoms=0, nsubgeoms;
> + GEOSGeometry* mline_out = 0;
> + GEOSGeometry* mpoint_out = 0;
> + GEOSGeometry* gout = 0;
> + uint32_t nlines = 0, nlines_alloc;
> + uint32_t npoints = 0;
> + uint32_t ngeoms = 0, nsubgeoms;
> uint32_t i, j;
> ngeoms = GEOSGetNumGeometries(gin);
> nlines_alloc = ngeoms;
> - lines = lwalloc(sizeof(GEOSGeometry*)*nlines_alloc);
> - points = lwalloc(sizeof(GEOSGeometry*)*ngeoms);
> + lines = lwalloc(sizeof(GEOSGeometry*) * nlines_alloc);
> + points = lwalloc(sizeof(GEOSGeometry*) * ngeoms);
> - for (i=0; i<ngeoms; ++i)
> + for (i = 0; i < ngeoms; ++i)
> const GEOSGeometry* g = GEOSGetGeometryN(gin, i);
> GEOSGeometry* vg;
> vg = LWGEOM_GEOS_makeValidLine(g);
> - if ( GEOSisEmpty(vg) )
> + if (GEOSisEmpty(vg))
> /* we don't care about this one */
> GEOSGeom_destroy(vg);
> - if ( GEOSGeomTypeId(vg) == GEOS_POINT )
> + if (GEOSGeomTypeId(vg) == GEOS_POINT)
> points[npoints++] = vg;
> - else if ( GEOSGeomTypeId(vg) == GEOS_LINESTRING )
> + else if (GEOSGeomTypeId(vg) == GEOS_LINESTRING)
> lines[nlines++] = vg;
> - else if ( GEOSGeomTypeId(vg) == GEOS_MULTILINESTRING )
> + else if (GEOSGeomTypeId(vg) == GEOS_MULTILINESTRING)
> - nsubgeoms=GEOSGetNumGeometries(vg);
> + nsubgeoms = GEOSGetNumGeometries(vg);
> nlines_alloc += nsubgeoms;
> - lines = lwrealloc(lines,
> - for (j=0; j<nsubgeoms; ++j)
> + lines = lwrealloc(lines, sizeof(GEOSGeometry*) *
> nlines_alloc);
> + for (j = 0; j < nsubgeoms; ++j)
> const GEOSGeometry* gc =
> GEOSGetGeometryN(vg, j);
> /* NOTE: ownership of the cloned geoms
> will be
> @@ -728,55 +673,39 @@
> /* NOTE: return from GEOSGeomType will leak
> * but we really don't expect this to happen */
> - lwerror("unexpected geom type returned "
> - "by LWGEOM_GEOS_makeValid: %s",
> - GEOSGeomType(vg));
> + lwerror("unexpected geom type returned by
> LWGEOM_GEOS_makeValid: %s", GEOSGeomType(vg));
> - if ( npoints )
> + if (npoints)
> - if ( npoints > 1 )
> - mpoint_out = GEOSGeom_createCollection(
> GEOS_MULTIPOINT,
> - points,
> npoints);
> + if (npoints > 1)
> + mpoint_out = GEOSGeom_createCollection(GEOS_MULTIPOINT,
> points, npoints);
> else
> mpoint_out = points[0];
> - if ( nlines )
> + if (nlines)
> - if ( nlines > 1 )
> - mline_out = GEOSGeom_createCollection(
> - GEOS_MULTILINESTRING, lines,
> nlines);
> + if (nlines > 1)
> + mline_out = GEOSGeom_createCollection(GEOS_MULTILINESTRING,
> lines, nlines);
> else
> mline_out = lines[0];
> lwfree(lines);
> - if ( mline_out && mpoint_out )
> + if (mline_out && mpoint_out)
> points[0] = mline_out;
> points[1] = mpoint_out;
> - gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
> - points, 2);
> + gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
> points, 2);
> - else if ( mline_out )
> + else if (mline_out)
> gout = mline_out;
> - else if ( mpoint_out )
> + else if (mpoint_out)
> gout = mpoint_out;
> lwfree(points);
> @@ -793,27 +722,31 @@
> LWGEOM_GEOS_makeValidCollection(const GEOSGeometry* gin)
> int nvgeoms;
> - GEOSGeometry **vgeoms;
> + GEOSGeometry** vgeoms;
> GEOSGeom gout;
> int i;
> nvgeoms = GEOSGetNumGeometries(gin);
> - if ( nvgeoms == -1 ) {
> + if (nvgeoms == -1)
> lwerror("GEOSGetNumGeometries: %s", lwgeom_geos_errmsg);
> return 0;
> - vgeoms = lwalloc( sizeof(GEOSGeometry*) * nvgeoms );
> - if ( ! vgeoms ) {
> + vgeoms = lwalloc(sizeof(GEOSGeometry*) * nvgeoms);
> + if (!vgeoms)
> lwerror("LWGEOM_GEOS_makeValidCollection: out of memory");
> return 0;
> - for ( i=0; i<nvgeoms; ++i ) {
> - vgeoms[i] = LWGEOM_GEOS_makeValid( GEOSGetGeometryN(gin,
> i) );
> - if ( ! vgeoms[i] ) {
> + for (i = 0; i < nvgeoms; ++i)
> + vgeoms[i] = LWGEOM_GEOS_makeValid(GEOSGetGeometryN(gin,
> i));
> + if (!vgeoms[i])
> int j;
> - for (j = 0; j<i-1; j++)
> + for (j = 0; j < i - 1; j++)
> GEOSGeom_destroy(vgeoms[j]);
> lwfree(vgeoms);
> /* we expect lwerror being called already by
> makeValid */
> @@ -823,22 +756,20 @@
> gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, vgeoms,
> nvgeoms);
> - for ( i=0; i<nvgeoms; ++i ) GEOSGeom_destroy(vgeoms[i]);
> + GEOSGeom_destroy(vgeoms[i]);
> lwfree(vgeoms);
> - lwerror("GEOSGeom_createCollection() threw an error: %s",
> + lwerror("GEOSGeom_createCollection() threw an error: %s",
> return NULL;
> lwfree(vgeoms);
> return gout;
> LWGEOM_GEOS_makeValid(const GEOSGeometry* gin)
> @@ -850,17 +781,15 @@
> ret_char = GEOSisValid(gin);
> - if ( ret_char == 2 )
> + if (ret_char == 2)
> /* I don't think should ever happen */
> lwerror("GEOSisValid(): %s", lwgeom_geos_errmsg);
> return NULL;
> - else if ( ret_char )
> + else if (ret_char)
> - LWDEBUGF(3,
> - "Geometry [%s] is valid. ",
> - lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)));
> + LWDEBUGF(3, "Geometry [%s] is valid. ",
> /* It's valid at this step, return what we have */
> return GEOSGeom_clone(gin);
> @@ -867,12 +796,10 @@
> LWDEBUGF(3,
> - "Geometry [%s] is still not valid: %s. "
> - "Will try to clean up further.",
> - lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)),
> + "Geometry [%s] is still not valid: %s. Will try to clean
> up further.",
> + lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)),
> * Step 3 : make what we got valid
> @@ -888,7 +815,7 @@
> gout = LWGEOM_GEOS_makeValidLine(gin);
> - if ( ! gout ) /* an exception or something */
> + if (!gout) /* an exception or something */
> lwerror("%s", lwgeom_geos_errmsg);
> @@ -898,7 +825,7 @@
> gout = LWGEOM_GEOS_makeValidMultiLine(gin);
> @@ -910,7 +837,7 @@
> gout = LWGEOM_GEOS_makeValidPolygon(gin);
> @@ -922,7 +849,7 @@
> gout = LWGEOM_GEOS_makeValidCollection(gin);
> @@ -934,8 +861,7 @@
> default:
> char* typname = GEOSGeomType(gin);
> - lwnotice("ST_MakeValid: doesn't support geometry type: %s",
> - typname);
> + lwnotice("ST_MakeValid: doesn't support geometry type:
> %s", typname);
> GEOSFree(typname);
> return NULL;
> break;
> @@ -944,35 +870,33 @@
> #if PARANOIA_LEVEL > 1
> - * Now check if every point of input is also found
> - * in output, or abort by returning NULL
> + * Now check if every point of input is also found in output, or
> * Input geometry was lwgeom_in
> - int loss;
> - GEOSGeometry *pi, *po, *pd;
> + int loss;
> + GEOSGeometry *pi, *po, *pd;
> - /* TODO: handle some errors here...
> - * Lack of exceptions is annoying indeed,
> - * I'm getting old --strk;
> - pi = GEOSGeom_extractUniquePoints(gin);
> - po = GEOSGeom_extractUniquePoints(gout);
> - pd = GEOSDifference(pi, po); /* input points -
> output points */
> - GEOSGeom_destroy(pi);
> - GEOSGeom_destroy(po);
> - loss = !GEOSisEmpty(pd);
> - GEOSGeom_destroy(pd);
> - if ( loss )
> - lwnotice("%s [%d] Vertices lost in
> LWGEOM_GEOS_makeValid", __FILE__, __LINE__);
> - /* return NULL */
> + /* TODO: handle some errors here...
> + * Lack of exceptions is annoying indeed,
> + * I'm getting old --strk;
> + pi = GEOSGeom_extractUniquePoints(gin);
> + po = GEOSGeom_extractUniquePoints(gout);
> + pd = GEOSDifference(pi, po); /* input points - output
> points */
> + GEOSGeom_destroy(pi);
> + GEOSGeom_destroy(po);
> + loss = !GEOSisEmpty(pd);
> + GEOSGeom_destroy(pd);
> + if (loss)
> + lwnotice("%s [%d] Vertices lost in
> + /* return NULL */
> #endif /* PARANOIA_LEVEL > 1 */
> return gout;
> @@ -983,7 +907,7 @@
> int is3d;
> GEOSGeom geosgeom;
> GEOSGeometry* geosout;
> - LWGEOM *lwgeom_out;
> + LWGEOM* lwgeom_out;
> is3d = FLAGS_GET_Z(lwgeom_in->flags);
> @@ -996,30 +920,24 @@
> lwgeom_out = lwgeom_in;
> geosgeom = LWGEOM2GEOS(lwgeom_out, 0);
> - if ( ! geosgeom )
> + if (!geosgeom)
> LWDEBUGF(4,
> - "Original geom can't be converted to GEOS
> (%s)"
> - " - will try cleaning that up first",
> + "Original geom can't be converted to GEOS (%s)"
> + " - will try cleaning that up first",
> lwgeom_out = lwgeom_make_geos_friendly(lwgeom_out);
> - if ( ! lwgeom_out )
> - lwerror("Could not make a valid geometry out of
> input");
> + if (!lwgeom_out) lwerror("Could not make a valid geometry
> out of input");
> /* try again as we did cleanup now */
> /* TODO: invoke LWGEOM2GEOS directly with autoclean ? */
> - if ( ! geosgeom )
> + if (!geosgeom)
> - lwerror("Couldn't convert POSTGIS geom to GEOS:
> %s",
> + lwerror("Couldn't convert POSTGIS geom to GEOS:
> return NULL;
> else
> @@ -1029,30 +947,26 @@
> geosout = LWGEOM_GEOS_makeValid(geosgeom);
> GEOSGeom_destroy(geosgeom);
> - if ( ! geosout )
> - return NULL;
> + if (!geosout) return NULL;
> lwgeom_out = GEOS2LWGEOM(geosout, is3d);
> GEOSGeom_destroy(geosout);
> - if ( lwgeom_is_collection(lwgeom_in) && !
> lwgeom_is_collection(lwgeom_out) )
> - LWGEOM **ogeoms = lwalloc(sizeof(LWGEOM*));
> - LWGEOM *ogeom;
> + if (lwgeom_is_collection(lwgeom_in) &&
> !lwgeom_is_collection(lwgeom_out))
> + LWGEOM** ogeoms = lwalloc(sizeof(LWGEOM*));
> + LWGEOM* ogeom;
> LWDEBUG(3, "lwgeom_make_valid: forcing multi");
> /* NOTE: this is safe because lwgeom_out is surely not
> lwgeom_in or
> * otherwise we couldn't have a collection and a
> non-collection */
> assert(lwgeom_in != lwgeom_out);
> ogeoms[0] = lwgeom_out;
> - ogeom = (LWGEOM *)lwcollection_construct(
> MULTITYPE[lwgeom_out->type],
> - lwgeom_out->srid,
> lwgeom_out->bbox, 1, ogeoms);
> + ogeom = (LWGEOM*)lwcollection_construct(
> + MULTITYPE[lwgeom_out->type], lwgeom_out->srid,
> lwgeom_out->bbox = NULL;
> lwgeom_out = ogeom;
> lwgeom_out->srid = lwgeom_in->srid;
> return lwgeom_out;
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180222/bdba2163/attachment-0001.html>
