[postgis-devel] [postgis-tickets] r16409 - Format lwgeom_geos_clean.c before digging in
Mateusz Loskot mateusz at loskot.net
Thu Feb 22 08:25:40 PST 2018
BTW, I'd recall similar issues here
https://github.com/postgis/postgis/pull/202/files/2bd0c00f398ba82fda64a5dc48e39d06fa667063#r165690882
ML
On 22 February 2018 at 17:18, Daniel Baston <dbaston at gmail.com> wrote:
> Why are you doing this? Was there a discussion to switch the code base to a
> new style?
> Dan
> On Thu, Feb 22, 2018 at 10:52 AM, Darafei <komzpa at gmail.com> wrote:
>> Author: komzpa
>> Date: 2018-02-22 07:52:47 -0800 (Thu, 22 Feb 2018)
>> New Revision: 16409
>> Modified:
>>    trunk/liblwgeom/lwgeom_geos_clean.c
>> Log:
>> References #2508
>> Modified: trunk/liblwgeom/lwgeom_geos_clean.c
>> --- trunk/liblwgeom/lwgeom_geos_clean.c 2018-02-22 13:42:00 UTC (rev
>> 16408)
>> +++ trunk/liblwgeom/lwgeom_geos_clean.c 2018-02-22 15:52:47 UTC (rev
>> 16409)
>> @@ -22,7 +22,6 @@
>>  #include "liblwgeom.h"
>>  #include "lwgeom_geos.h"
>>  #include "liblwgeom_internal.h"
>> @@ -36,7 +35,6 @@
>>  /* #define PARANOIA_LEVEL 2 */
>>  #undef LWGEOM_PROFILE_MAKEVALID
>>   * Return Nth vertex in GEOSGeometry as a POINT.
>>   * May return NULL if the geometry has NO vertexex.
>> @@ -53,7 +51,7 @@
>>         int gn;
>>         GEOSGeometry* ret;
>> -       switch ( GEOSGeomTypeId(g_in) )
>> +       switch (GEOSGeomTypeId(g_in))
>>         case GEOS_MULTIPOINT:
>>         case GEOS_MULTILINESTRING:
>> @@ -60,11 +58,11 @@
>>         case GEOS_MULTIPOLYGON:
>>         case GEOS_GEOMETRYCOLLECTION:
>> -               for (gn=0; gn<GEOSGetNumGeometries(g_in); ++gn)
>> +               for (gn = 0; gn < GEOSGetNumGeometries(g_in); ++gn)
>>                         const GEOSGeometry* g = GEOSGetGeometryN(g_in,
>> gn);
>> -                       ret = LWGEOM_GEOS_getPointN(g,n);
>> -                       if ( ret ) return ret;
>> +                       ret = LWGEOM_GEOS_getPointN(g, n);
>> +                       if (ret) return ret;
>>                 break;
>> @@ -72,12 +70,12 @@
>>         case GEOS_POLYGON:
>>                 ret = LWGEOM_GEOS_getPointN(GEOSGetExteriorRing(g_in), n);
>> -               for (gn=0; gn<GEOSGetNumInteriorRings(g_in); ++gn)
>> +               for (gn = 0; gn < GEOSGetNumInteriorRings(g_in); ++gn)
>>                         const GEOSGeometry* g = GEOSGetInteriorRingN(g_in,
>> gn);
>>                 break;
>> @@ -86,37 +84,34 @@
>>         case GEOS_LINESTRING:
>>         case GEOS_LINEARRING:
>>                 break;
>>         seq_in = GEOSGeom_getCoordSeq(g_in);
>> -       if ( ! seq_in ) return NULL;
>> -       if ( ! GEOSCoordSeq_getSize(seq_in, &sz) ) return NULL;
>> -       if ( ! sz ) return NULL;
>> +       if (!seq_in) return NULL;
>> +       if (!GEOSCoordSeq_getSize(seq_in, &sz)) return NULL;
>> +       if (!sz) return NULL;
>> -       if ( ! GEOSCoordSeq_getDimensions(seq_in, &dims) ) return NULL;
>> +       if (!GEOSCoordSeq_getDimensions(seq_in, &dims)) return NULL;
>>         seq_out = GEOSCoordSeq_create(1, dims);
>> -       if ( ! seq_out ) return NULL;
>> +       if (!seq_out) return NULL;
>> -       if ( ! GEOSCoordSeq_getX(seq_in, n, &val) ) return NULL;
>> -       if ( ! GEOSCoordSeq_setX(seq_out, n, val) ) return NULL;
>> -       if ( ! GEOSCoordSeq_getY(seq_in, n, &val) ) return NULL;
>> -       if ( ! GEOSCoordSeq_setY(seq_out, n, val) ) return NULL;
>> -       if ( dims > 2 )
>> +       if (!GEOSCoordSeq_getX(seq_in, n, &val)) return NULL;
>> +       if (!GEOSCoordSeq_setX(seq_out, n, val)) return NULL;
>> +       if (!GEOSCoordSeq_getY(seq_in, n, &val)) return NULL;
>> +       if (!GEOSCoordSeq_setY(seq_out, n, val)) return NULL;
>> +       if (dims > 2)
>> -               if ( ! GEOSCoordSeq_getZ(seq_in, n, &val) ) return NULL;
>> -               if ( ! GEOSCoordSeq_setZ(seq_out, n, val) ) return NULL;
>> +               if (!GEOSCoordSeq_getZ(seq_in, n, &val)) return NULL;
>> +               if (!GEOSCoordSeq_setZ(seq_out, n, val)) return NULL;
>>         return GEOSGeom_createPoint(seq_out);
>> -LWGEOM * lwcollection_make_geos_friendly(LWCOLLECTION *g);
>> -LWGEOM * lwline_make_geos_friendly(LWLINE *line);
>> -LWGEOM * lwpoly_make_geos_friendly(LWPOLY *poly);
>> +LWGEOM* lwcollection_make_geos_friendly(LWCOLLECTION* g);
>> +LWGEOM* lwline_make_geos_friendly(LWLINE* line);
>> +LWGEOM* lwpoly_make_geos_friendly(LWPOLY* poly);
>>  POINTARRAY* ring_make_geos_friendly(POINTARRAY* ring);
>> @@ -125,8 +120,8 @@
>>   * May return the input untouched (if already valid).
>>   * May return geometries of lower dimension (on collapses)
>> -static LWGEOM *
>> -lwgeom_make_geos_friendly(LWGEOM *geom)
>> +static LWGEOM*
>> +lwgeom_make_geos_friendly(LWGEOM* geom)
>>         LWDEBUGF(2, "lwgeom_make_geos_friendly enter (type %d)",
>> geom->type);
>>         switch (geom->type)
>> @@ -139,18 +134,18 @@
>>         case LINETYPE:
>>                 /* lines need at least 2 points */
>> -               return lwline_make_geos_friendly((LWLINE *)geom);
>> +               return lwline_make_geos_friendly((LWLINE*)geom);
>>                 break;
>>         case POLYGONTYPE:
>>                 /* polygons need all rings closed and with npoints > 3 */
>> -               return lwpoly_make_geos_friendly((LWPOLY *)geom);
>> +               return lwpoly_make_geos_friendly((LWPOLY*)geom);
>>                 break;
>>         case MULTILINETYPE:
>>         case MULTIPOLYGONTYPE:
>>         case COLLECTIONTYPE:
>> -               return lwcollection_make_geos_friendly((LWCOLLECTION
>> *)geom);
>> +               return
>> lwcollection_make_geos_friendly((LWCOLLECTION*)geom);
>>                 break;
>>         case CIRCSTRINGTYPE:
>> @@ -159,7 +154,9 @@
>>         case MULTISURFACETYPE:
>>         case MULTICURVETYPE:
>>         default:
>> -               lwerror("lwgeom_make_geos_friendly: unsupported input
>> geometry type: %s (%d)", lwtype_name(geom->type), geom->type);
>> +               lwerror("lwgeom_make_geos_friendly: unsupported input
>> +                       lwtype_name(geom->type),
>> +                       geom->type);
>>                 break;
>>         return 0;
>> @@ -178,13 +175,10 @@
>>         POINTARRAY* newring;
>>         /* close the ring if not already closed (2d only) */
>> -       if ( ! ptarray_is_closed_2d(ring) )
>> +       if (!ptarray_is_closed_2d(ring))
>>                 /* close it up */
>> -               newring = ptarray_addPoint(ring,
>> -                                          getPoint_internal(ring, 0),
>> -                                          FLAGS_NDIMS(ring->flags),
>> -                                          ring->npoints);
>> +               newring = ptarray_addPoint(ring, getPoint_internal(ring,
>> 0), FLAGS_NDIMS(ring->flags), ring->npoints);
>>                 ring = newring;
>>         return ring;
>> @@ -199,26 +193,19 @@
>>         closedring = ptarray_close2d(ring);
>> -       if (closedring != ring )
>> -               ring = closedring;
>> +       if (closedring != ring) ring = closedring;
>>         /* return 0 for collapsed ring (after closeup) */
>> -       while ( ring->npoints < 4 )
>> +       while (ring->npoints < 4)
>> -               POINTARRAY *oring = ring;
>> +               POINTARRAY* oring = ring;
>>                 LWDEBUGF(4, "ring has %d points, adding another",
>> ring->npoints);
>>                 /* let's add another... */
>> -               ring = ptarray_addPoint(ring,
>> -                                       ring->npoints);
>> -               if ( oring != ring_in ) ptarray_free(oring);
>> +               ring = ptarray_addPoint(ring, getPoint_internal(ring, 0),
>> +               if (oring != ring_in) ptarray_free(oring);
>>         return ring;
>> @@ -225,36 +212,35 @@
>>  /* Make sure all rings are closed and have > 3 points.
>>   * May return the input untouched.
>> -LWGEOM *
>> -lwpoly_make_geos_friendly(LWPOLY *poly)
>> +LWGEOM*
>> +lwpoly_make_geos_friendly(LWPOLY* poly)
>>         LWGEOM* ret;
>> -       POINTARRAY **new_rings;
>> +       POINTARRAY** new_rings;
>>         uint32_t i;
>>         /* If the polygon has no rings there's nothing to do */
>> -       if ( ! poly->nrings ) return (LWGEOM*)poly;
>> +       if (!poly->nrings) return (LWGEOM*)poly;
>>         /* Allocate enough pointers for all rings */
>> -       new_rings = lwalloc(sizeof(POINTARRAY*)*poly->nrings);
>> +       new_rings = lwalloc(sizeof(POINTARRAY*) * poly->nrings);
>>         /* All rings must be closed and have > 3 points */
>> -       for (i=0; i<poly->nrings; i++)
>> +       for (i = 0; i < poly->nrings; i++)
>>                 POINTARRAY* ring_in = poly->rings[i];
>>                 POINTARRAY* ring_out = ring_make_geos_friendly(ring_in);
>> -               if ( ring_in != ring_out )
>> +               if (ring_in != ring_out)
>> -                       LWDEBUGF(3, "lwpoly_make_geos_friendly: ring %d
>> cleaned, now has %d points", i, ring_out->npoints);
>> +                       LWDEBUGF(
>> +                           3, "lwpoly_make_geos_friendly: ring %d
>>                         ptarray_free(ring_in);
>>                 else
>> untouched", i);
>> -               assert ( ring_out );
>> +               assert(ring_out);
>>                 new_rings[i] = ring_out;
>> @@ -266,10 +252,10 @@
>>  /* Need NO or >1 points. Duplicate first if only one. */
>> -LWGEOM *
>> -lwline_make_geos_friendly(LWLINE *line)
>> +LWGEOM*
>> +lwline_make_geos_friendly(LWLINE* line)
>> -       LWGEOM *ret;
>> +       LWGEOM* ret;
>>         if (line->points->npoints == 1) /* 0 is fine, 2 is fine */
>> @@ -276,9 +262,9 @@
>>  #if 1
>>                 /* Duplicate point */
>>                 line->points = ptarray_addPoint(line->points,
>> getPoint_internal(line->points, 0),
>> FLAGS_NDIMS(line->points->flags),
>> -                                               line->points->npoints);
>> +                                               line->points->npoints);
>>                 ret = (LWGEOM*)line;
>>  #else
>>                 /* Turn into a point */
>> @@ -293,38 +279,36 @@
>> -LWGEOM *
>> -lwcollection_make_geos_friendly(LWCOLLECTION *g)
>> +LWGEOM*
>> +lwcollection_make_geos_friendly(LWCOLLECTION* g)
>> -       LWGEOM **new_geoms;
>> -       uint32_t i, new_ngeoms=0;
>> -       LWCOLLECTION *ret;
>> +       LWGEOM** new_geoms;
>> +       uint32_t i, new_ngeoms = 0;
>> +       LWCOLLECTION* ret;
>>         /* enough space for all components */
>> -       new_geoms = lwalloc(sizeof(LWGEOM *)*g->ngeoms);
>> +       new_geoms = lwalloc(sizeof(LWGEOM*) * g->ngeoms);
>>         ret = lwalloc(sizeof(LWCOLLECTION));
>>         memcpy(ret, g, sizeof(LWCOLLECTION));
>> -    ret->maxgeoms = g->ngeoms;
>> +       ret->maxgeoms = g->ngeoms;
>> -       for (i=0; i<g->ngeoms; i++)
>> +       for (i = 0; i < g->ngeoms; i++)
>>                 LWGEOM* newg = lwgeom_make_geos_friendly(g->geoms[i]);
>> -               if ( newg ) new_geoms[new_ngeoms++] = newg;
>> +               if (newg) new_geoms[new_ngeoms++] = newg;
>>         ret->bbox = NULL; /* recompute later... */
>>         ret->ngeoms = new_ngeoms;
>> -       if ( new_ngeoms )
>> +       if (new_ngeoms)
>>                 ret->geoms = new_geoms;
>>         else
>>                 free(new_geoms);
>>                 ret->geoms = NULL;
>> -        ret->maxgeoms = 0;
>> +               ret->maxgeoms = 0;
>>         return (LWGEOM*)ret;
>> @@ -347,14 +331,12 @@
>>         point = LWGEOM_GEOS_getPointN(lines, 0);
>> -       if ( ! point ) return NULL;
>> +       if (!point) return NULL;
>> -       LWDEBUGF(3,
>> -                      "Boundary point: %s",
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(point, 0)));
>> +       LWDEBUGF(3, "Boundary point: %s",
>>         noded = GEOSUnion(lines, point);
>> -       if ( NULL == noded )
>> +       if (NULL == noded)
>>                 GEOSGeom_destroy(point);
>>                 return NULL;
>> @@ -363,9 +345,9 @@
>>         LWDEBUGF(3,
>> -                      "LWGEOM_GEOS_nodeLines: in[%s] out[%s]",
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(lines, 0)),
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(noded, 0)));
>> +                "LWGEOM_GEOS_nodeLines: in[%s] out[%s]",
>> +                lwgeom_to_ewkt(GEOS2LWGEOM(lines, 0)),
>> +                lwgeom_to_ewkt(GEOS2LWGEOM(noded, 0)));
>>         return noded;
>> @@ -381,31 +363,24 @@
>>         GEOSGeom gout;
>>         GEOSGeom geos_bound;
>>         GEOSGeom geos_cut_edges, geos_area, collapse_points;
>> -       GEOSGeometry *vgeoms[3]; /* One for area, one for cut-edges */
>> -       unsigned int nvgeoms=0;
>> +       GEOSGeometry* vgeoms[3]; /* One for area, one for cut-edges */
>> +       unsigned int nvgeoms = 0;
>> -       assert (GEOSGeomTypeId(gin) == GEOS_POLYGON ||
>> -               GEOSGeomTypeId(gin) == GEOS_MULTIPOLYGON);
>> +       assert(GEOSGeomTypeId(gin) == GEOS_POLYGON || GEOSGeomTypeId(gin)
>>         geos_bound = GEOSBoundary(gin);
>> -       if ( NULL == geos_bound )
>> -               return NULL;
>> +       if (NULL == geos_bound) return NULL;
>> -       LWDEBUGF(3,
>> -                      "Boundaries: %s",
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(geos_bound, 0)));
>> +       LWDEBUGF(3, "Boundaries: %s",
>>         /* Use noded boundaries as initial "cut" edges */
>>  #ifdef LWGEOM_PROFILE_MAKEVALID
>> -  lwnotice("ST_MakeValid: noding lines");
>> +       lwnotice("ST_MakeValid: noding lines");
>>  #endif
>>         geos_cut_edges = LWGEOM_GEOS_nodeLines(geos_bound);
>> -       if ( NULL == geos_cut_edges )
>> +       if (NULL == geos_cut_edges)
>>                 GEOSGeom_destroy(geos_bound);
>>                 lwnotice("LWGEOM_GEOS_nodeLines(): %s",
>> lwgeom_geos_errmsg);
>> @@ -419,46 +394,40 @@
>>                 GEOSGeometry* po;
>> -    lwnotice("ST_MakeValid: extracting unique points from bounds");
>> +               lwnotice("ST_MakeValid: extracting unique points from
>> bounds");
>>  #endif
>>                 pi = GEOSGeom_extractUniquePoints(geos_bound);
>> -               if ( NULL == pi )
>> +               if (NULL == pi)
>> -                       lwnotice("GEOSGeom_extractUniquePoints(): %s",
>> -                                lwgeom_geos_errmsg);
>> +                       lwnotice("GEOSGeom_extractUniquePoints(): %s",
>>                         return NULL;
>> -               LWDEBUGF(3,
>> -                              "Boundaries input points %s",
>> -                              lwgeom_to_ewkt(GEOS2LWGEOM(pi, 0)));
>> +               LWDEBUGF(3, "Boundaries input points %s",
>> -    lwnotice("ST_MakeValid: extracting unique points from cut_edges");
>> cut_edges");
>>  #endif
>>                 po = GEOSGeom_extractUniquePoints(geos_cut_edges);
>> -               if ( NULL == po )
>> +               if (NULL == po)
>>                         GEOSGeom_destroy(pi);
>>                         return NULL;
>> -               LWDEBUGF(3,
>> -                              "Boundaries output points %s",
>> -                              lwgeom_to_ewkt(GEOS2LWGEOM(po, 0)));
>> +               LWDEBUGF(3, "Boundaries output points %s",
>> -    lwnotice("ST_MakeValid: find collapse points");
>> +               lwnotice("ST_MakeValid: find collapse points");
>>  #endif
>>                 collapse_points = GEOSDifference(pi, po);
>> -               if ( NULL == collapse_points )
>> +               if (NULL == collapse_points)
>> @@ -467,12 +436,10 @@
>>                         return NULL;
>> -               LWDEBUGF(3,
>> -                              "Collapse points: %s",
>> -                              lwgeom_to_ewkt(GEOS2LWGEOM(collapse_points,
>> 0)));
>> +               LWDEBUGF(3, "Collapse points: %s",
>> lwgeom_to_ewkt(GEOS2LWGEOM(collapse_points, 0)));
>> -    lwnotice("ST_MakeValid: cleanup(1)");
>> +               lwnotice("ST_MakeValid: cleanup(1)");
>>  #endif
>> @@ -480,13 +447,11 @@
>> -       LWDEBUGF(3,
>> -                      "Noded Boundaries: %s",
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(geos_cut_edges, 0)));
>> +       LWDEBUGF(3, "Noded Boundaries: %s",
>>         /* And use an empty geometry as initial "area" */
>>         geos_area = GEOSGeom_createEmptyPolygon();
>> -       if ( ! geos_area )
>> +       if (!geos_area)
>>                 lwnotice("GEOSGeom_createEmptyPolygon(): %s",
>>                 GEOSGeom_destroy(geos_cut_edges);
>> @@ -501,13 +466,13 @@
>>         while (GEOSGetNumGeometries(geos_cut_edges))
>> -               GEOSGeometry* new_area=0;
>> -               GEOSGeometry* new_area_bound=0;
>> -               GEOSGeometry* symdif=0;
>> -               GEOSGeometry* new_cut_edges=0;
>> +               GEOSGeometry* new_area = 0;
>> +               GEOSGeometry* new_area_bound = 0;
>> +               GEOSGeometry* symdif = 0;
>> +               GEOSGeometry* new_cut_edges = 0;
>> -    lwnotice("ST_MakeValid: building area from %d edges",
>> GEOSGetNumGeometries(geos_cut_edges));
>> +               lwnotice("ST_MakeValid: building area from %d edges",
>>  #endif
>> @@ -515,16 +480,15 @@
>>                 new_area = LWGEOM_GEOS_buildArea(geos_cut_edges);
>> -               if ( ! new_area )   /* must be an exception */
>> +               if (!new_area) /* must be an exception */
>>                         GEOSGeom_destroy(geos_area);
>> -                       lwnotice("LWGEOM_GEOS_buildArea() threw an error:
>> %s",
>> +                       lwnotice("LWGEOM_GEOS_buildArea() threw an error:
>> %s", lwgeom_geos_errmsg);
>>                         return NULL;
>> -               if ( GEOSisEmpty(new_area) )
>> +               if (GEOSisEmpty(new_area))
>>                         /* no more rings can be build with thes edges */
>>                         GEOSGeom_destroy(new_area);
>> @@ -536,7 +500,8 @@
>> -    lwnotice("ST_MakeValid: ring built with %d cut edges, saving
>> boundaries", GEOSGetNumGeometries(geos_cut_edges));
>> +               lwnotice("ST_MakeValid: ring built with %d cut edges,
>> saving boundaries",
>> +                        GEOSGetNumGeometries(geos_cut_edges));
>>  #endif
>> @@ -544,13 +509,13 @@
>>                  * further cut edges later)
>>                 new_area_bound = GEOSBoundary(new_area);
>> -               if ( ! new_area_bound )
>> +               if (!new_area_bound)
>>                         /* We did check for empty area already so
>>                          * this must be some other error */
>>                         lwnotice("GEOSBoundary('%s') threw an error: %s",
>> -                                lwgeom_to_ewkt(GEOS2LWGEOM(new_area, 0)),
>> +                                lwgeom_to_ewkt(GEOS2LWGEOM(new_area, 0)),
>> +                                lwgeom_geos_errmsg);
>>                         return NULL;
>> @@ -557,7 +522,7 @@
>> -    lwnotice("ST_MakeValid: running SymDifference with new area");
>> +               lwnotice("ST_MakeValid: running SymDifference with new
>> area");
>>  #endif
>> @@ -564,14 +529,13 @@
>>                  * Now symdif new and old area
>>                 symdif = GEOSSymDifference(geos_area, new_area);
>> -               if ( ! symdif )   /* must be an exception */
>> +               if (!symdif) /* must be an exception */
>>                         GEOSGeom_destroy(new_area_bound);
>> -                       lwnotice("GEOSSymDifference() threw an error: %s",
>> +                       lwnotice("GEOSSymDifference() threw an error: %s",
>>                         return NULL;
>> @@ -592,19 +556,18 @@
>> -    lwnotice("ST_MakeValid: computing new cut_edges (GEOSDifference)");
>> +               lwnotice("ST_MakeValid: computing new cut_edges
>> (GEOSDifference)");
>>  #endif
>>                 new_cut_edges = GEOSDifference(geos_cut_edges,
>> new_area_bound);
>> -               if ( ! new_cut_edges )   /* an exception ? */
>> +               if (!new_cut_edges) /* an exception ? */
>>                         /* cleanup and throw */
>>                         /* TODO: Shouldn't this be an lwerror ? */
>> -                       lwnotice("GEOSDifference() threw an error: %s",
>> +                       lwnotice("GEOSDifference() threw an error: %s",
>>                         return NULL;
>> @@ -612,37 +575,25 @@
>> -  lwnotice("ST_MakeValid: final checks");
>> +       lwnotice("ST_MakeValid: final checks");
>>  #endif
>> -       if ( ! GEOSisEmpty(geos_area) )
>> +       if (!GEOSisEmpty(geos_area))
>>                 vgeoms[nvgeoms++] = geos_area;
>>         else
>> -       if ( ! GEOSisEmpty(geos_cut_edges) )
>> +       if (!GEOSisEmpty(geos_cut_edges))
>>                 vgeoms[nvgeoms++] = geos_cut_edges;
>>         else
>> -       if ( ! GEOSisEmpty(collapse_points) )
>> +       if (!GEOSisEmpty(collapse_points))
>>                 vgeoms[nvgeoms++] = collapse_points;
>>         else
>>                 GEOSGeom_destroy(collapse_points);
>> -       if ( 1 == nvgeoms )
>> +       if (1 == nvgeoms)
>>                 /* Return cut edges */
>>                 gout = vgeoms[0];
>> @@ -651,12 +602,11 @@
>>                 /* Collect areas and lines (if any line) */
>>                 gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
>> vgeoms, nvgeoms);
>> -               if ( ! gout )   /* an exception again */
>> +               if (!gout) /* an exception again */
>> -                       lwnotice("GEOSGeom_createCollection() threw an
>> error: %s",
>> +                       lwnotice("GEOSGeom_createCollection() threw an
>> error: %s", lwgeom_geos_errmsg);
>>                         /* TODO: cleanup! */
>>                         return NULL;
>> @@ -663,7 +613,6 @@
>>         return gout;
>>  static GEOSGeometry*
>> @@ -679,44 +628,40 @@
>>         GEOSGeometry** lines;
>>         GEOSGeometry** points;
>> -       GEOSGeometry* mline_out=0;
>> -       GEOSGeometry* mpoint_out=0;
>> -       GEOSGeometry* gout=0;
>> -       uint32_t nlines=0, nlines_alloc;
>> -       uint32_t npoints=0;
>> -       uint32_t ngeoms=0, nsubgeoms;
>> +       GEOSGeometry* mline_out = 0;
>> +       GEOSGeometry* mpoint_out = 0;
>> +       GEOSGeometry* gout = 0;
>> +       uint32_t nlines = 0, nlines_alloc;
>> +       uint32_t npoints = 0;
>> +       uint32_t ngeoms = 0, nsubgeoms;
>>         uint32_t i, j;
>>         ngeoms = GEOSGetNumGeometries(gin);
>>         nlines_alloc = ngeoms;
>> -       lines = lwalloc(sizeof(GEOSGeometry*)*nlines_alloc);
>> -       points = lwalloc(sizeof(GEOSGeometry*)*ngeoms);
>> +       lines = lwalloc(sizeof(GEOSGeometry*) * nlines_alloc);
>> +       points = lwalloc(sizeof(GEOSGeometry*) * ngeoms);
>> -       for (i=0; i<ngeoms; ++i)
>> +       for (i = 0; i < ngeoms; ++i)
>>                 const GEOSGeometry* g = GEOSGetGeometryN(gin, i);
>>                 GEOSGeometry* vg;
>>                 vg = LWGEOM_GEOS_makeValidLine(g);
>> -               if ( GEOSisEmpty(vg) )
>> +               if (GEOSisEmpty(vg))
>>                         /* we don't care about this one */
>>                         GEOSGeom_destroy(vg);
>> -               if ( GEOSGeomTypeId(vg) == GEOS_POINT )
>> +               if (GEOSGeomTypeId(vg) == GEOS_POINT)
>>                         points[npoints++] = vg;
>> -               else if ( GEOSGeomTypeId(vg) == GEOS_LINESTRING )
>> +               else if (GEOSGeomTypeId(vg) == GEOS_LINESTRING)
>>                         lines[nlines++] = vg;
>> -               else if ( GEOSGeomTypeId(vg) == GEOS_MULTILINESTRING )
>> +               else if (GEOSGeomTypeId(vg) == GEOS_MULTILINESTRING)
>> -                       nsubgeoms=GEOSGetNumGeometries(vg);
>> +                       nsubgeoms = GEOSGetNumGeometries(vg);
>>                         nlines_alloc += nsubgeoms;
>> -                       lines = lwrealloc(lines,
>> -                       for (j=0; j<nsubgeoms; ++j)
>> +                       lines = lwrealloc(lines, sizeof(GEOSGeometry*) *
>> nlines_alloc);
>> +                       for (j = 0; j < nsubgeoms; ++j)
>>                                 const GEOSGeometry* gc =
>> GEOSGetGeometryN(vg, j);
>>                                 /* NOTE: ownership of the cloned geoms
>> will be
>> @@ -728,55 +673,39 @@
>>                         /* NOTE: return from GEOSGeomType will leak
>>                          * but we really don't expect this to happen */
>> -                       lwerror("unexpected geom type returned "
>> -                               "by LWGEOM_GEOS_makeValid: %s",
>> -                               GEOSGeomType(vg));
>> +                       lwerror("unexpected geom type returned by
>> LWGEOM_GEOS_makeValid: %s", GEOSGeomType(vg));
>> -       if ( npoints )
>> +       if (npoints)
>> -               if ( npoints > 1 )
>> -                       mpoint_out =
>> GEOSGeom_createCollection(GEOS_MULTIPOINT,
>> -                                                              points,
>> npoints);
>> +               if (npoints > 1)
>> +                       mpoint_out =
>> GEOSGeom_createCollection(GEOS_MULTIPOINT, points, npoints);
>>                 else
>>                         mpoint_out = points[0];
>> -       if ( nlines )
>> +       if (nlines)
>> -               if ( nlines > 1 )
>> -                       mline_out = GEOSGeom_createCollection(
>> -                                       GEOS_MULTILINESTRING, lines,
>> nlines);
>> +               if (nlines > 1)
>> +                       mline_out =
>> GEOSGeom_createCollection(GEOS_MULTILINESTRING, lines, nlines);
>>                 else
>>                         mline_out = lines[0];
>>         lwfree(lines);
>> -       if ( mline_out && mpoint_out )
>> +       if (mline_out && mpoint_out)
>>                 points[0] = mline_out;
>>                 points[1] = mpoint_out;
>> -               gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
>> -                                                points, 2);
>> +               gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
>> points, 2);
>> -       else if ( mline_out )
>> +       else if (mline_out)
>>                 gout = mline_out;
>> -       else if ( mpoint_out )
>> +       else if (mpoint_out)
>>                 gout = mpoint_out;
>>         lwfree(points);
>> @@ -793,27 +722,31 @@
>>  LWGEOM_GEOS_makeValidCollection(const GEOSGeometry* gin)
>>         int nvgeoms;
>> -       GEOSGeometry **vgeoms;
>> +       GEOSGeometry** vgeoms;
>>         GEOSGeom gout;
>>         int i;
>>         nvgeoms = GEOSGetNumGeometries(gin);
>> -       if ( nvgeoms == -1 ) {
>> +       if (nvgeoms == -1)
>>                 lwerror("GEOSGetNumGeometries: %s", lwgeom_geos_errmsg);
>>                 return 0;
>> -       vgeoms = lwalloc( sizeof(GEOSGeometry*) * nvgeoms );
>> -       if ( ! vgeoms ) {
>> +       vgeoms = lwalloc(sizeof(GEOSGeometry*) * nvgeoms);
>> +       if (!vgeoms)
>>                 lwerror("LWGEOM_GEOS_makeValidCollection: out of memory");
>>                 return 0;
>> -       for ( i=0; i<nvgeoms; ++i ) {
>> -               vgeoms[i] = LWGEOM_GEOS_makeValid( GEOSGetGeometryN(gin,
>> i) );
>> -               if ( ! vgeoms[i] ) {
>> +       for (i = 0; i < nvgeoms; ++i)
>> +               vgeoms[i] = LWGEOM_GEOS_makeValid(GEOSGetGeometryN(gin,
>> i));
>> +               if (!vgeoms[i])
>>                         int j;
>> -                       for (j = 0; j<i-1; j++)
>> +                       for (j = 0; j < i - 1; j++)
>>                                 GEOSGeom_destroy(vgeoms[j]);
>>                         lwfree(vgeoms);
>>                         /* we expect lwerror being called already by
>> makeValid */
>> @@ -823,22 +756,20 @@
>>         gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, vgeoms,
>> nvgeoms);
>> -               for ( i=0; i<nvgeoms; ++i ) GEOSGeom_destroy(vgeoms[i]);
>> +                       GEOSGeom_destroy(vgeoms[i]);
>>                 lwfree(vgeoms);
>> -               lwerror("GEOSGeom_createCollection() threw an error: %s",
>> +               lwerror("GEOSGeom_createCollection() threw an error: %s",
>>                 return NULL;
>>         lwfree(vgeoms);
>>         return gout;
>>  LWGEOM_GEOS_makeValid(const GEOSGeometry* gin)
>> @@ -850,17 +781,15 @@
>>         ret_char = GEOSisValid(gin);
>> -       if ( ret_char == 2 )
>> +       if (ret_char == 2)
>>                 /* I don't think should ever happen */
>>                 lwerror("GEOSisValid(): %s", lwgeom_geos_errmsg);
>>                 return NULL;
>> -       else if ( ret_char )
>> +       else if (ret_char)
>> -               LWDEBUGF(3,
>> -                              "Geometry [%s] is valid. ",
>> -                              lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)));
>> +               LWDEBUGF(3, "Geometry [%s] is valid. ",
>>                 /* It's valid at this step, return what we have */
>>                 return GEOSGeom_clone(gin);
>> @@ -867,12 +796,10 @@
>>         LWDEBUGF(3,
>> -                      "Geometry [%s] is still not valid: %s. "
>> -                      "Will try to clean up further.",
>> -                      lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)),
>> +                "Geometry [%s] is still not valid: %s. Will try to clean
>> up further.",
>> +                lwgeom_to_ewkt(GEOS2LWGEOM(gin, 0)),
>>          * Step 3 : make what we got valid
>> @@ -888,7 +815,7 @@
>>                 gout = LWGEOM_GEOS_makeValidLine(gin);
>> -               if ( ! gout )  /* an exception or something */
>> +               if (!gout) /* an exception or something */
>>                         lwerror("%s", lwgeom_geos_errmsg);
>> @@ -898,7 +825,7 @@
>>                 gout = LWGEOM_GEOS_makeValidMultiLine(gin);
>> @@ -910,7 +837,7 @@
>>                 gout = LWGEOM_GEOS_makeValidPolygon(gin);
>> @@ -922,7 +849,7 @@
>>                 gout = LWGEOM_GEOS_makeValidCollection(gin);
>> @@ -934,8 +861,7 @@
>>         default:
>>                 char* typname = GEOSGeomType(gin);
>> -               lwnotice("ST_MakeValid: doesn't support geometry type:
>> %s",
>> -                        typname);
>> +               lwnotice("ST_MakeValid: doesn't support geometry type:
>> %s", typname);
>>                 GEOSFree(typname);
>>                 return NULL;
>>                 break;
>> @@ -944,35 +870,33 @@
>>  #if PARANOIA_LEVEL > 1
>> -        * Now check if every point of input is also found
>> -        * in output, or abort by returning NULL
>> +        * Now check if every point of input is also found in output, or
>>          * Input geometry was lwgeom_in
>> -                       int loss;
>> -                       GEOSGeometry *pi, *po, *pd;
>> +               int loss;
>> +               GEOSGeometry *pi, *po, *pd;
>> -                       /* TODO: handle some errors here...
>> -                        * Lack of exceptions is annoying indeed,
>> -                        * I'm getting old --strk;
>> -                       pi = GEOSGeom_extractUniquePoints(gin);
>> -                       po = GEOSGeom_extractUniquePoints(gout);
>> -                       pd = GEOSDifference(pi, po); /* input points -
>> output points */
>> -                       GEOSGeom_destroy(pi);
>> -                       GEOSGeom_destroy(po);
>> -                       loss = !GEOSisEmpty(pd);
>> -                       GEOSGeom_destroy(pd);
>> -                       if ( loss )
>> -                               lwnotice("%s [%d] Vertices lost in
>> LWGEOM_GEOS_makeValid", __FILE__, __LINE__);
>> -                               /* return NULL */
>> +               /* TODO: handle some errors here...
>> +                * Lack of exceptions is annoying indeed,
>> +                * I'm getting old --strk;
>> +               pi = GEOSGeom_extractUniquePoints(gin);
>> +               po = GEOSGeom_extractUniquePoints(gout);
>> +               pd = GEOSDifference(pi, po); /* input points - output
>> points */
>> +               GEOSGeom_destroy(pi);
>> +               GEOSGeom_destroy(po);
>> +               loss = !GEOSisEmpty(pd);
>> +               GEOSGeom_destroy(pd);
>> +               if (loss)
>> +                       lwnotice("%s [%d] Vertices lost in
>> +                       /* return NULL */
>>  #endif /* PARANOIA_LEVEL > 1 */
>>         return gout;
>> @@ -983,7 +907,7 @@
>>         int is3d;
>>         GEOSGeom geosgeom;
>>         GEOSGeometry* geosout;
>> -       LWGEOM *lwgeom_out;
>> +       LWGEOM* lwgeom_out;
>>         is3d = FLAGS_GET_Z(lwgeom_in->flags);
>> @@ -996,30 +920,24 @@
>>         lwgeom_out = lwgeom_in;
>>         geosgeom = LWGEOM2GEOS(lwgeom_out, 0);
>> -       if ( ! geosgeom )
>> +       if (!geosgeom)
>>                 LWDEBUGF(4,
>> -                              "Original geom can't be converted to GEOS
>> (%s)"
>> -                              " - will try cleaning that up first",
>> +                        "Original geom can't be converted to GEOS (%s)"
>> +                        " - will try cleaning that up first",
>>                 lwgeom_out = lwgeom_make_geos_friendly(lwgeom_out);
>> -               if ( ! lwgeom_out )
>> -                       lwerror("Could not make a valid geometry out of
>> input");
>> +               if (!lwgeom_out) lwerror("Could not make a valid geometry
>> out of input");
>>                 /* try again as we did cleanup now */
>>                 /* TODO: invoke LWGEOM2GEOS directly with autoclean ? */
>> -               if ( ! geosgeom )
>> +               if (!geosgeom)
>> -                       lwerror("Couldn't convert POSTGIS geom to GEOS:
>> %s",
>> +                       lwerror("Couldn't convert POSTGIS geom to GEOS:
>>                         return NULL;
>>         else
>> @@ -1029,30 +947,26 @@
>>         geosout = LWGEOM_GEOS_makeValid(geosgeom);
>>         GEOSGeom_destroy(geosgeom);
>> -       if ( ! geosout )
>> -               return NULL;
>> +       if (!geosout) return NULL;
>>         lwgeom_out = GEOS2LWGEOM(geosout, is3d);
>>         GEOSGeom_destroy(geosout);
>> -       if ( lwgeom_is_collection(lwgeom_in) && !
>> lwgeom_is_collection(lwgeom_out) )
>> -               LWGEOM **ogeoms = lwalloc(sizeof(LWGEOM*));
>> -               LWGEOM *ogeom;
>> +       if (lwgeom_is_collection(lwgeom_in) &&
>> !lwgeom_is_collection(lwgeom_out))
>> +               LWGEOM** ogeoms = lwalloc(sizeof(LWGEOM*));
>> +               LWGEOM* ogeom;
>>                 LWDEBUG(3, "lwgeom_make_valid: forcing multi");
>>                 /* NOTE: this is safe because lwgeom_out is surely not
>> lwgeom_in or
>>                  * otherwise we couldn't have a collection and a
>> non-collection */
>>                 assert(lwgeom_in != lwgeom_out);
>>                 ogeoms[0] = lwgeom_out;
>> -               ogeom = (LWGEOM
>> *)lwcollection_construct(MULTITYPE[lwgeom_out->type],
>> -                                         lwgeom_out->srid,
>> lwgeom_out->bbox, 1, ogeoms);
>> +               ogeom = (LWGEOM*)lwcollection_construct(
>> +                   MULTITYPE[lwgeom_out->type], lwgeom_out->srid,
>>                 lwgeom_out->bbox = NULL;
>>                 lwgeom_out = ogeom;
>>         lwgeom_out->srid = lwgeom_in->srid;
>>         return lwgeom_out;
>> postgis-tickets mailing list
>> postgis-tickets at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Mateusz Loskot, http://mateusz.loskot.net
