[postgis-devel] Code formatting digging in
Raúl Marín Rodríguez
rmrodriguez at carto.com
Thu Feb 22 08:59:25 PST 2018
Komzpa was doing some tests with clang-format in GH[1], but apparently it
was
having some issues with the codebase.
Even if it's not automatic (as part of the PR process) I would be happy
having
a .clang-format file with the accepted style in the project to use it
locally
(as a precommit check). The "accepted style" is the important par here as it
should work globally (and not per file / folder).
[1] https://github.com/postgis/postgis/pull/188
*Raúl Marín Rodríguez *carto.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180222/30d118c1/attachment.html>
