[postgis-devel] Code formatting digging in
Tomas Vondra tomas.vondra at 2ndquadrant.com
Fri Feb 23 05:51:39 PST 2018
On 02/23/2018 12:21 PM, Sandro Santilli wrote:
> On Thu, Feb 22, 2018 at 11:26:39PM +0100, Tomas Vondra wrote:
>> AFAIK that only includes header files, so no - pgindent is not there.
>> But it's not like it's a massive tool - you can get it here:
>>     https://github.com/postgres/postgres/tree/master/src/tools/pgindent
>> and include it in PostGIS. Or to be more precise, it's a separate tool
>> available here:
>>     https://git.postgresql.org/git/pg_bsd_indent.git
> Ok then it would be good for our use.
> Sum of *.c *.h and README* is 160K vs. 664K of astyle.
> And pg_bsd_indent is C code instaed of C++, which means we don't
> need to require an additional compiler.
>> Not really, it tends to be very stable. One of the primary reasons why
>> we have pgindent is to make all the branches more alike, to make
>> back-patching simpler. Changing the formatting rules between releases
>> would directly contradict that.
> I'm sold, did I hear you volunteering to send a PR for integration
> of that package in PostGIS ? Or I'll get to that eventually.
I can do that, yes. I suggest we do that in two steps:
1) getting the tooling in - essentially copy of src/tools/pgindent with
changes to paths, exclude patterns, Makefile stuff, etc.
2) initial run on the code base - I have no idea how noisy this will get
at this point. It should be done on all supported branches, otherwise
it'll make back-patching more difficult.
I don't think (1) should be committed until there's a clear idea how
much noise (2) will cause. That is, let's get (1) and (2) ready,
evaluate the results and then decide if pgindent is the right choice.
regards
Tomas Vondra                  http://www.2ndQuadrant.com
PostgreSQL Development, 24x7 Support, Remote DBA, Training & Services
