[postgis-devel] World Sinusoidal Projection in PostGIS
G. Allegri
giohappy at gmail.com
Fri Jan 5 02:35:09 PST 2018
I don't have my pc right now to verify, but in that case you can insert it
by hand using the proj4 definition: http://epsg.io/54008.proj4
Giovanni
Il 5 gen 2018 11:14 AM, "José María" <jmamuedo at gmail.com> ha scritto:
> Thanks G. Allegri.
> But the problem is I don´t get any response with that query. So, that
> means my PostGIS has not this srid=54008.
> (Postgresql 9.6 PostGIS 2.0)
> 2018-01-05 11:06 GMT+01:00 G. Allegri <giohappy at gmail.com>:
>> World sinusoidal is EPSG:54008 so I guess it's proj string [1] is
>> already inside the spatial_ref_sys table, which is where CRS definitions
>> are defined in PostGIS.
>> You can verify it doing:
>> SELECT * FROM spatial_ref_sys WHERE srid = 54008
>> Giovanni
>> [1] http://epsg.io/54008.proj4
>> Il 5 gen 2018 10:46 AM, "José María" <jmamuedo at gmail.com> ha scritto:
>>> Hi,
>>> I spent several days searching info about how to use Worl Sinusoidal
>>> porjection in PostGIS. But I didn´t find any responses.
>>> I only found a possible codification (54008) in ESRI, but I don´t know
>>> how to manage this projection in PostGIS.
>>> Any people can I help me with this discussion?
>>> Thanks.
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180105/fbf31e41/attachment.html>
