[postgis-devel] World Sinusoidal Projection in PostGIS
José María
jmamuedo at gmail.com
Wed Jan 10 02:09:49 PST 2018
The question is I´m no sure if this reference system is the correct to
define a Sinusoidal Projection from MODIS.
Anyone may give me advise.
Thanks,
J.M.
2018-01-05 11:35 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> I don't have my pc right now to verify, but in that case you can insert it
> by hand using the proj4 definition: http://epsg.io/54008.proj4
> Giovanni
> Il 5 gen 2018 11:14 AM, "José María" <jmamuedo at gmail.com> ha scritto:
>> Thanks G. Allegri.
>> But the problem is I don´t get any response with that query. So, that
>> means my PostGIS has not this srid=54008.
>> (Postgresql 9.6 PostGIS 2.0)
>> 2018-01-05 11:06 GMT+01:00 G. Allegri <giohappy at gmail.com>:
>>> World sinusoidal is EPSG:54008 so I guess it's proj string [1] is
>>> already inside the spatial_ref_sys table, which is where CRS definitions
>>> are defined in PostGIS.
>>> You can verify it doing:
>>> SELECT * FROM spatial_ref_sys WHERE srid = 54008
>>> Giovanni
>>> [1] http://epsg.io/54008.proj4
>>> Il 5 gen 2018 10:46 AM, "José María" <jmamuedo at gmail.com> ha scritto:
>>>> Hi,
>>>> I spent several days searching info about how to use Worl Sinusoidal
>>>> porjection in PostGIS. But I didn´t find any responses.
>>>> I only found a possible codification (54008) in ESRI, but I don´t know
>>>> how to manage this projection in PostGIS.
>>>> Any people can I help me with this discussion?
>>>> Thanks.
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180110/a5e01b37/attachment.html>
