[postgis-devel] TPI with custom focal mean radius
Luis Calisto luis.calisto at hotmail.com
Thu Jul 5 02:29:40 PDT 2018
Current ST_TPI implementation only supports a focalmean radius of one. Out of need I had to implement a solution in PostGIS that implements TPI with a custom focal mean. This solution is now on my github: https://github.com/lcalisto/postgis_customTPI/ I believe it can be interesting to contribute this code to current ST_TPI implementation maybe someone else also needs it.
You think we should reopen this ticket? https://trac.osgeo.org/postgis/ticket/2163
If you think it's interesting I can also, and easily, do the same for TRI. https://postgis.net/docs/RT_ST_TRI.html
Regards
Luis Calisto
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180705/30f8dedc/attachment.html>
