[postgis-devel] TPI with custom focal mean radius
Regina Obe lr at pcorp.us
Thu Jul 5 03:31:22 PDT 2018
Luis,
Unfortunately we are at feature freeze for PostGIS 2.5.0, so this can't go
into PostGIS 2.5.0 since it would change/add  signatures
We also wouldn't reopen the ticket, but would require a new ticket detailing
the enhancement.
Could go in for next release which is tentatively planned to be 3.0 (at
least a year's away).  We'll be focusing on this at  our upcoming code
sprint in late September
https://trac.osgeo.org/postgis/wiki/PostGISCodeSprint2018
which you are welcome to join if you want to hack on PostGIS stuff.
That said, a couple of changes we'd need for this to accept.
Ideally, this would extend the existing ST_TPI with additional args, so the
following changes would need to be made
1)      A new ticket detailing the enhancement
2)      Change name to ST_TPI
3)      Move the irad, and orad to the end - so that the signature is
backward compatible with the existing ST_TPI signature.
4)      Add regression tests
5)      Amend  https://postgis.net/docs/RT_ST_TRI.html no include new
signature
There's some other stuff about how you upgrade an existing function to
accept new args, but I can take care of that and just explain for future
contributions.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf
Of Luis Calisto
Sent: Thursday, July 05, 2018 5:30 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] TPI with custom focal mean radius
Current ST_TPI implementation only supports a focalmean radius of one. Out
of need I had to implement a solution in PostGIS that implements TPI with a
custom focal mean. This solution is now on my github:
https://github.com/lcalisto/postgis_customTPI/ I believe it can be
interesting to contribute this code to current ST_TPI implementation maybe
someone else also needs it.
You think we should reopen this ticket?
https://trac.osgeo.org/postgis/ticket/2163
If you think it's interesting I can also, and easily, do the same for TRI.
Regards
Luis Calisto
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180705/981de9ef/attachment.html>
