[postgis-devel] PostGIS 2.5.0beta1 is released
Greg Troxel
gdt at lexort.com
Sat Jul 7 19:50:46 PDT 2018
"Regina Obe" <lr at pcorp.us> writes:
> The PostGIS development team is pleased to release PostGIS 2.5.0beta1.
I testeed with goes 3.6.2, gdal 2.2.4, and pgsql 9.5.13. All tests
passed, except that I have some gdal/raster issue in pgsql - but that is
not new with this postgis version.
My complete (not committed) diff for the package update follows. It
mostly looks ok, but the removal of the dev-- upgrade line looks incorrect.
> This release is a work in progress. No more api changes will be made from
> this point on before 2.5.0 release. Remaining time will be focused on bug
> fixes and documentation for the new functionality and performance
> enhancements under the covers. Although this release will work for
> PostgreSQL 9.4 and above, to take full advantage of what PostGIS 2.5 will
> offer, you should be running PostgreSQL 11beta2+ and GEOS 3.7.0beta1 which
> were released recently.
> Best served with PostgreSQL 11beta2 which was recently released -
> https://www.postgresql.org/about/news/1867/
Do you know when geos 3.7 and pgsql 11 will be released, and will this
release be held up until then? It's irregular for a release to
recommend an unreleased version of some depdency, so it would be good to
adjust the wording.
Index: Makefile
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/Makefile,v
retrieving revision 1.45
diff -u -p -r1.45 Makefile
--- Makefile 30 May 2018 17:03:56 -0000 1.45
+++ Makefile 8 Jul 2018 02:43:55 -0000
@@ -1,7 +1,7 @@
# $NetBSD: Makefile,v 1.45 2018/05/30 17:03:56 gdt Exp $
-MAJOR= 2.4
-DISTNAME= postgis-${MAJOR}.4
+MAJOR= 2.5
+DISTNAME= postgis-${MAJOR}.0beta1
PKGNAME= postgresql${PGSQL_VERSION}-${DISTNAME}
CATEGORIES= databases geography
MASTER_SITES= https://download.osgeo.org/postgis/source/
Index: PLIST
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/PLIST,v
retrieving revision 1.14
diff -u -p -r1.14 PLIST
--- PLIST 30 May 2018 17:03:56 -0000 1.14
+++ PLIST 8 Jul 2018 02:43:55 -0000
@@ -72,10 +72,12 @@ share/postgresql/extension/postgis--2.4.
share/postgresql/extension/postgis--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis--${PKGVERSION}.sql
-share/postgresql/extension/postgis--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis.control
share/postgresql/extension/postgis_tiger_geocoder--2.0.0--${PKGVERSION}.sql
@@ -116,13 +118,14 @@ share/postgresql/extension/postgis_tiger
share/postgresql/extension/postgis_tiger_geocoder--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}.sql
-share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder.control
-share/postgresql/extension/postgis_tiger_geocoder.sql
share/postgresql/extension/postgis_topology--2.0.0--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.0.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.0.2--${PKGVERSION}.sql
@@ -161,9 +164,11 @@ share/postgresql/extension/postgis_topol
share/postgresql/extension/postgis_topology--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}.sql
-share/postgresql/extension/postgis_topology--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology.control
Index: distinfo
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/distinfo,v
retrieving revision 1.15
diff -u -p -r1.15 distinfo
--- distinfo 30 May 2018 12:03:46 -0000 1.15
+++ distinfo 8 Jul 2018 02:43:55 -0000
@@ -1,6 +1,6 @@
$NetBSD: distinfo,v 1.15 2018/05/30 12:03:46 gdt Exp $
-SHA1 (postgis-2.4.4.tar.gz) = 8e75a337b19fad01b14a69fc741835fbb1f985bc
-RMD160 (postgis-2.4.4.tar.gz) = f9d5274a25b9e9e05a6f25343c9185bcd1fa4b3a
-SHA512 (postgis-2.4.4.tar.gz) = 3cb38ee24dad72a66677cb210ad5f07b0a97411664ede582a5cdbc0ca2d72573db4e9121b6af2eab9cdee6a41122c3f5c59e618df4ee028a3cae7ee35d8670f2
-Size (postgis-2.4.4.tar.gz) = 12608016 bytes
+SHA1 (postgis-2.5.0beta1.tar.gz) = 3bd7b4958af38f0c884972a4220dadc285bd6859
+RMD160 (postgis-2.5.0beta1.tar.gz) = e17a64ede1a9992040c501bc16fba2a85ef60c36
+SHA512 (postgis-2.5.0beta1.tar.gz) = 5640feb89a35f95a7d3fcef0addf604c18bf7f1d3162ddf471ee1cc14208a09f97dfd8f5bf4df9bf79206fa69500b2997556d71431ee1a47e8c72c1b45382798
+Size (postgis-2.5.0beta1.tar.gz) = 15093477 bytes
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180707/42936ddc/attachment.sig>
