[postgis-devel] PostGIS 2.5.0beta1 is released
Greg Troxel
gdt at lexort.com
Mon Jul 9 09:58:01 PDT 2018
"Regina Obe" <lr at pcorp.us> writes:
> I don't bother including the dev upgrade version cause it's an extra thing
> and I figure anybody testing would be
> a) testing from the alpha release
> b) would be smart enough to add back the dev if they were testing from say
> 2.5.0beta1dev
> When release time comes, I'm planning to remove all the alphas and rcs as
> well.
> RC I may consider keeping.
> Thoughts?
My basic thought is that this churn in file lists and the large number
of upgrade scripts is a major source of packaging pain. I suspect half
my editing time for a new release is dealing with this. (pkgsrc chooses
to have a list that's under CM, so that changes from that list are
detected, which often happens when things change in the environment.)
It seems that in the 2.4.4 release, there was a 2.4.4dev to 2.4.4
upgrade script. Along with next. See attached diff from current
pkgsrc to draft 2.5.0 package.
I don't really care what's in or out. It would just be nice if it were
written down how it's supposed to be and not change.
Alternatively, if this really is all the same file, and symlinks, then
if whatever uses it could just use the ANY file, and we could only
install things that are actually different, that would be even better.
Index: Makefile
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/Makefile,v
retrieving revision 1.45
diff -u -p -r1.45 Makefile
--- Makefile 30 May 2018 17:03:56 -0000 1.45
+++ Makefile 8 Jul 2018 02:43:55 -0000
@@ -1,7 +1,7 @@
# $NetBSD: Makefile,v 1.45 2018/05/30 17:03:56 gdt Exp $
-MAJOR= 2.4
-DISTNAME= postgis-${MAJOR}.4
+MAJOR= 2.5
+DISTNAME= postgis-${MAJOR}.0beta1
PKGNAME= postgresql${PGSQL_VERSION}-${DISTNAME}
CATEGORIES= databases geography
MASTER_SITES= https://download.osgeo.org/postgis/source/
Index: PLIST
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/PLIST,v
retrieving revision 1.14
diff -u -p -r1.14 PLIST
--- PLIST 30 May 2018 17:03:56 -0000 1.14
+++ PLIST 8 Jul 2018 02:43:55 -0000
@@ -72,10 +72,12 @@ share/postgresql/extension/postgis--2.4.
share/postgresql/extension/postgis--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis--${PKGVERSION}.sql
-share/postgresql/extension/postgis--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis.control
share/postgresql/extension/postgis_tiger_geocoder--2.0.0--${PKGVERSION}.sql
@@ -116,13 +118,14 @@ share/postgresql/extension/postgis_tiger
share/postgresql/extension/postgis_tiger_geocoder--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}.sql
-share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder.control
-share/postgresql/extension/postgis_tiger_geocoder.sql
share/postgresql/extension/postgis_topology--2.0.0--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.0.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.0.2--${PKGVERSION}.sql
@@ -161,9 +164,11 @@ share/postgresql/extension/postgis_topol
share/postgresql/extension/postgis_topology--2.4.1--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.4.2--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--2.5.0alpha--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}.sql
-share/postgresql/extension/postgis_topology--${PKGVERSION}dev--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--ANY--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--unpackaged--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology.control
Index: distinfo
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/distinfo,v
retrieving revision 1.15
diff -u -p -r1.15 distinfo
--- distinfo 30 May 2018 12:03:46 -0000 1.15
+++ distinfo 8 Jul 2018 02:43:55 -0000
@@ -1,6 +1,6 @@
$NetBSD: distinfo,v 1.15 2018/05/30 12:03:46 gdt Exp $
-SHA1 (postgis-2.4.4.tar.gz) = 8e75a337b19fad01b14a69fc741835fbb1f985bc
-RMD160 (postgis-2.4.4.tar.gz) = f9d5274a25b9e9e05a6f25343c9185bcd1fa4b3a
-SHA512 (postgis-2.4.4.tar.gz) = 3cb38ee24dad72a66677cb210ad5f07b0a97411664ede582a5cdbc0ca2d72573db4e9121b6af2eab9cdee6a41122c3f5c59e618df4ee028a3cae7ee35d8670f2
-Size (postgis-2.4.4.tar.gz) = 12608016 bytes
+SHA1 (postgis-2.5.0beta1.tar.gz) = 3bd7b4958af38f0c884972a4220dadc285bd6859
+RMD160 (postgis-2.5.0beta1.tar.gz) = e17a64ede1a9992040c501bc16fba2a85ef60c36
+SHA512 (postgis-2.5.0beta1.tar.gz) = 5640feb89a35f95a7d3fcef0addf604c18bf7f1d3162ddf471ee1cc14208a09f97dfd8f5bf4df9bf79206fa69500b2997556d71431ee1a47e8c72c1b45382798
+Size (postgis-2.5.0beta1.tar.gz) = 15093477 bytes
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180709/d1b0f2ee/attachment.sig>
