[postgis-devel] PostGIS 2.3 build not honouring pg_config flags
Pavan Deolasee
pavan.deolasee at gmail.com
Wed Jul 11 01:48:36 PDT 2018
Hi Raúl,
On Wed, Jul 11, 2018 at 1:56 PM, Raúl Marín Rodríguez <rmrodriguez at carto.com
> wrote:
> Hi Pavan,
> If it's working correctly in svn-trunk my bet is that it was solved by
> these two patches:
> - https://trac.osgeo.org/postgis/changeset/16582
> - https://trac.osgeo.org/postgis/changeset/16544
> Could you give them a try?
Yes, 16544 does the trick. I did not try the other because the problem I am
trying to fix is in postgis, but I am sure the other change will be
required too. What's the project policy? Don't we typically back patch such
changes to the older branches? Or was it just an oversight?
Thanks,
Pavan
Pavan Deolasee http://www.2ndQuadrant.com/
PostgreSQL Development, 24x7 Support, Training & Services
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180711/6eeb34f0/attachment.html>
