[postgis-devel] [SoC]Week 10 Report - Implement Geospatial Data Viewer in pgAdmin4 for PostGIS
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jul 30 11:01:33 PDT 2018
OK, that branch builds... there's just functionality for looking at
geometries one-at-a-time, is there a plan for a map view that shows
the whole result set?
P.
On Fri, Jul 27, 2018 at 6:23 PM, Xuri Gong <xurigoong at gmail.com> wrote:
> Hi Paul,
> Since there are some bugs using openlayers in pgadmin4, I have replaced it
> with leafletjs in 'geometry_visualiser' branch. Please use
> 'geometry_visualiser' branch to build:
> https://github.com/Gooong/pgadmin4/tree/geometry_visualiser
> Thank you:)
> Paul Ramsey <pramsey at cleverelephant.ca> 于2018年7月28日周六 上午5:26写道:
>> Trying out the geoviewer branch,
>> I can run 'make bundle' fine in the master branch. In your branch it
>> errors out like this:
>> ERROR in ./pgadmin/static/jsx/map_view/map_view.jsx
>> Module not found: Error: Can't resolve 'ol/dist/ol.js' in
>> '/Users/pramsey/Code/pgadmin4/web/pgadmin/static/jsx/map_view'
>> @ ./pgadmin/static/jsx/map_view/map_view.jsx 60:9-33
>> @ ./pgadmin/tools/sqleditor/static/js/sqleditor.js
>> ERROR in ./pgadmin/static/jsx/map_view/map_view_map.jsx
>> @ ./pgadmin/static/jsx/map_view/map_view_map.jsx 37:9-33
>> error Command failed with exit code 2.
>> info Visit https://yarnpkg.com/en/docs/cli/run for documentation about
>> this command.
>> I assume there's a small piece of configuration not checked in somewhere?
>> On Sun, Jul 22, 2018 at 7:00 PM, Xuri Gong <xurigoong at gmail.com> wrote:
>> > Hi,
>> > I am Xuri Gong. This is my report for week 10(July 16 - 22).
>> > What did you get done this period?
>> > Create visualiser for individual geometry in datagrid. [1]
>> > Fix image url errors in leaflet. [2]
>> > This visualiser is independent from the geoviewer and is in the
>> > geometry_visualiser branch[3]. Here is the screen shot:
>> > Screenshot 1 [4]
>> > Screenshot 2 [5]
>> > What do you plan on doing next week?
>> > Create test for both geometry_visualiser and geoviewer.
>> > Check the code style to meet the pgAdmin coding standards[6].
>> > Are you blocked on anything?
>> > No, I am not blocked.
>> > Wiki page: [7]
>> > Public repository: [8]
>> > [1]
>> > https://github.com/Gooong/pgadmin4/commit/d6407baa3a0a96adac169d183bed8bc044dbb8f5
>> > [2]
>> > https://github.com/Gooong/pgadmin4/commit/3b160b668c4f9b5867b4b2189714c934a5de85c6
>> > [3] https://github.com/Gooong/pgadmin4/tree/geometry_visualiser
>> > [4] https://photos.app.goo.gl/kH58WDbZeKAtRvNi8
>> > [5] https://photos.app.goo.gl/AnQMZndMQ62HGLmbA
>> > [6] https://pgadmin.org/docs/pgadmin4/dev/coding_standards.html
>> > [7]
>> > https://trac.osgeo.org/postgis/wiki/GeospatialDataViewerInPgAdmin4ForPostGIS
>> > [8] https://github.com/Gooong/pgadmin4/tree/geoviewer
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
