[postgis-devel] [SoC]Week 10 Report - Implement Geospatial Data Viewer in pgAdmin4 for PostGIS
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 30 11:08:59 PDT 2018
Also, do you find the OSM tileserver slow? I find it's incredibly
slow. Maybe using bing or some other public-but-available tile set
would be good?
P
On Mon, Jul 30, 2018 at 11:01 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> OK, that branch builds... there's just functionality for looking at
> geometries one-at-a-time, is there a plan for a map view that shows
> the whole result set?
> P.
> On Fri, Jul 27, 2018 at 6:23 PM, Xuri Gong <xurigoong at gmail.com> wrote:
>> Hi Paul,
>> Since there are some bugs using openlayers in pgadmin4, I have replaced it
>> with leafletjs in 'geometry_visualiser' branch. Please use
>> 'geometry_visualiser' branch to build:
>> https://github.com/Gooong/pgadmin4/tree/geometry_visualiser
>> Thank you:)
>> Paul Ramsey <pramsey at cleverelephant.ca> 于2018年7月28日周六 上午5:26写道:
>>> Trying out the geoviewer branch,
>>> I can run 'make bundle' fine in the master branch. In your branch it
>>> errors out like this:
>>> ERROR in ./pgadmin/static/jsx/map_view/map_view.jsx
>>> Module not found: Error: Can't resolve 'ol/dist/ol.js' in
>>> '/Users/pramsey/Code/pgadmin4/web/pgadmin/static/jsx/map_view'
>>>  @ ./pgadmin/static/jsx/map_view/map_view.jsx 60:9-33
>>>  @ ./pgadmin/tools/sqleditor/static/js/sqleditor.js
>>> ERROR in ./pgadmin/static/jsx/map_view/map_view_map.jsx
>>>  @ ./pgadmin/static/jsx/map_view/map_view_map.jsx 37:9-33
>>> error Command failed with exit code 2.
>>> info Visit https://yarnpkg.com/en/docs/cli/run for documentation about
>>> this command.
>>> I assume there's a small piece of configuration not checked in somewhere?
>>> On Sun, Jul 22, 2018 at 7:00 PM, Xuri Gong <xurigoong at gmail.com> wrote:
>>> > Hi,
>>> > I am Xuri Gong. This is my report for week 10(July 16 - 22).
>>> > What did you get done this period?
>>> > Create visualiser for individual geometry in datagrid. [1]
>>> > Fix image url errors in leaflet. [2]
>>> > This visualiser is independent from the geoviewer and is in the
>>> > geometry_visualiser branch[3]. Here is the screen shot:
>>> > Screenshot 1 [4]
>>> > Screenshot 2 [5]
>>> > What do you plan on doing next week?
>>> > Create test for both geometry_visualiser and geoviewer.
>>> > Check the code style to meet the pgAdmin coding standards[6].
>>> > Are you blocked on anything?
>>> > No, I am not blocked.
>>> > Wiki page: [7]
>>> > Public repository: [8]
>>> > [1]
>>> > https://github.com/Gooong/pgadmin4/commit/d6407baa3a0a96adac169d183bed8bc044dbb8f5
>>> > [2]
>>> > https://github.com/Gooong/pgadmin4/commit/3b160b668c4f9b5867b4b2189714c934a5de85c6
>>> > [3] https://github.com/Gooong/pgadmin4/tree/geometry_visualiser
>>> > [4] https://photos.app.goo.gl/kH58WDbZeKAtRvNi8
>>> > [5] https://photos.app.goo.gl/AnQMZndMQ62HGLmbA
>>> > [6] https://pgadmin.org/docs/pgadmin4/dev/coding_standards.html
>>> > [7]
>>> > https://trac.osgeo.org/postgis/wiki/GeospatialDataViewerInPgAdmin4ForPostGIS
>>> > [8] https://github.com/Gooong/pgadmin4/tree/geoviewer
>>> > _______________________________________________
>>> > postgis-devel mailing list
>>> > postgis-devel at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
