[postgis-devel] Regarding Raster RFC2 edit (r16452)
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat Mar 10 23:58:35 PST 2018
https://trac.osgeo.org/postgis/changeset/16452 is performed by Bborie Park
and not me.
Can this be re-addressed? :)
вс, 11 мар. 2018 г. в 10:15, Sandro Santilli <strk at kbt.io>:
> Komzpa I saw you modified RFC2-WellKnownBinaryFormat in r16452 but
> didn't read any thread on postgis-devel reguarding the change.
> Those documents are important references and should be changed
> lightly so please revert the change and propose changes on this
> mailing list.
> Note that the header of the file contains revision information,
> which you didn't update with your changes.
> Specifically your change shifted the last 2 "pixtype" values from
> 9,10 to 10,10 thus leaving a gap in 9:
> | pixtype | 4bits | 0: 1-bit boolean |
> | | | 1: 2-bit unsigned integer |
> | | | 2: 4-bit unsigned integer |
> | | | 3: 8-bit signed integer |
> | | | 4: 8-bit unsigned integer |
> | | | 5: 16-bit signed integer |
> | | | 6: 16-bit unsigned signed integer |
> | | | 7: 32-bit signed integer |
> | | | 8: 32-bit unsigned signed integer |
> | | | 10: 32-bit float |
> | | | 11: 64-bit float |
> Is it possible you're updating RFC to match some buggy code ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180311/16c1c6cd/attachment.html>
