[postgis-devel] performance test suite
Even Rouault even.rouault at spatialys.com
Tue May 1 12:41:26 PDT 2018
On mardi 1 mai 2018 19:05:12 CEST Björn Harrtell wrote:
> Hi devs,
> In recent times I've been pondering on about how to make a sensible test
> suite specifically for performance. Hacking/extending run_test.pl to
> accommodate for this has been the only suggested path forward but to me
> it's a dead end mostly because of perl (sorry)-
> The reason why this has become a to me apparent missing thing is due to:
> 1. My own work on https://trac.osgeo.org/postgis/ticket/4076.
> 2. The recently discovered large performance regression of ST_Union tracked
> by https://trac.osgeo.org/postgis/ticket/4075. Even if it's in GEOS and
> could perhaps be performance tested there, I think it would not be wrong to
> also performance test ST_Union without consideration of underlying
> implementation.
> Any additional thoughts on the subject? do it in perl or don't do it? :)
When last year I worked on openjpeg improvements, one task I tackled was to try to put in
place performance tests that would run when continuous integration triggers so as to be
able to detect precisely when performance loss or improvement would happen. The only
semi reliable way I found with Travis-CI (hope nobody is following some thread on
board at list.osgeo.org !) is to do a build and run on the same machine before (previous
commit or last stable version) and after the change, with elimination of outliers etc. In the
openjpeg context, it turned out to be not reliable enough to be used to flag a build as KO
performance-wise, since I was chasing for changes in performance of  1% to 2% and so that
was within the noise of the measurement (noise due to the non deterministic nature of
modern OS + probably the effect of cloud based machines). If you just need to detech
regressions of speed > 10% that could probably be reliable enough.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180501/a69d2f4a/attachment.html>
