[postgis-devel] performance test suite
Regina Obe
lr at pcorp.us
Tue May 1 13:47:43 PDT 2018
> probably the effect of cloud based machines). If you just need to detech
regressions of speed > 10% that could probably be reliable enough.
> Even
I think in our case we are concerned with the > 50% like the time I put in
set_path in all the functions and dbaston noticed hey ST_Distance takes 10
times longer than it used to :)
It's so easy to change what one things is a simple config parameter and have
the speeds plummet.
Of course those tend to be more glaringly obvious. The catching the < 10%
regression speed would be a dream :)
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180501/685d5fbe/attachment-0001.html>
