[postgis-devel] Error creating postgis extension
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 25 16:41:05 PDT 2018
You should not need 5.2 for the geodetic stuff, that definitely pre-dates 5.
P
> On Oct 25, 2018, at 3:05 PM, Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> On Thu, 2018-10-25 at 12:45 +0100, Paul Ramsey wrote:
>> Looks like a libproj version mismatch? Maybe the spec file for 2.5 needs to
>> peg a minimum libproj version? Let me confirm…
> I built it against Proj 4.9.3. I can work on packaging Proj 5.2, but it also
> requires a custom GDAL package as well, so the amount of work is non-trivial.
> I'll do that , if I really have to.
> Regards,
> Devrim Gündüz
> EnterpriseDB: https://www.enterprisedb.com
> PostgreSQL Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
