[postgis-devel] NEWS file cleanup ?
Daniel Baston dbaston at gmail.com
Fri Sep 14 04:35:09 PDT 2018
I've had some confusion about which NEWS files should get an entry for a
bug fix. It looks like some fixes are put in the NEWS for all maintained
branches, while others are put only in the NEWS for the oldest maintained
branch.
On Fri, Sep 14, 2018 at 7:24 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> I think current process of writing a NEWS entry on every ticket is good.
> It helps a lot when investingating environment differences: you see a bug
> on some, say, RDS database, and can't reproduce it locally. You then take
> your latest version and read NEWS top-to-bottom until you see a line
> mentioning your issue, which has a link to ticket. It sometimes has
> workarounds there :)
> Doing it by commit messages is much less fun, as they often don't mention
> high-level manifestation of bug (like "crash in ANALYZE"), but a way of
> fixing ("Handle almost-infinite features when building table statistics").
> Or, sometimes, it can be dozens of commits until a fix is found.
> Some pre-release rearrangement of NEWS, like sorting most-to-least
> interesting, grouping similar issues, merging alpha-beta-rc and combining
> issues that were added and fixed in between is a good plan though.
> пт, 14 сент. 2018 г. в 14:02, Greg Troxel <gdt at lexort.com>:
>> "Regina Obe" <lr at pcorp.us> writes:
>> > Strk,
>> > I was planning to get rid of all that bug stuff on final release
>> > notes.  I feel noting those changes (even bugs) in RCs is important
>> > otherwise how will people know what to test?
>> I stand with strk here :-)
>> People testing RCs have read the email message announcing the RC, so it
>> can be there instead.
>> Also, in the longstandin GNU tradition (which is where NEWS came from)
>> bug fixes do not generally belong in NEWS, unless the bug is notorious.
>> It's supposed to be about significant changes, like removed and new
>> APIs, new user programs, new dependency/compiler requirements, and
>> things those using the program need to adapt to.
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180914/f4685063/attachment.html>
