[postgis-devel] PSC Vote: Drop the minor in the postgis lib files
Greg Troxel
gdt at lexort.com
Thu Sep 27 05:36:00 PDT 2018
Sandro Santilli <strk at kbt.io> writes:
> I guess you want to do this for bots to prevent them testing the
> wrong library in a parallel tests run from different branches ?
> But doing so would mean the bots won't test the default naming of
> libraries. Maybe let's postpone this (and the switch needs a better
> name anyway)
Regardless, tests need to be constructed so that installed libraries
(those that are part of what's being tested) are not used, in general.
It seems better to really fix this if it's needed, than to have a
workaround.
