[postgis-devel] Geos 3.7.0 / autoconf question
Sandro Santilli
strk at kbt.io
Sat Sep 29 00:41:14 PDT 2018
On Thu, Sep 27, 2018 at 05:26:52PM -0400, John Harvey wrote:
> Maybe a better question would be-- is there a way I can test my compilation
> of geos 3.7.0 on CentOS 6 with autoconf 2.63 to validate that it seems to
> be working correctly?
Run: make && make check
If `make check` passes you're good to go.
I'm happy for you to _lower_ that requirement if it's not
really needed.
--strk;
