[postgis-devel] Using pkg-config for PROJ
Regina Obe
lr at pcorp.us
Fri Feb 8 17:22:09 PST 2019
> > The only annoying thing about relying on pkg-config is that since I
> > install things in non-standard paths so I can swap in and out
> > different versions of things, I have to fiddle with the
> > PKG_CONFIG_PATH env variable or insure that all my pkg-config files
> > are in my path variable.
> Actually, I think that's less annoying that figuring out what
--with-foo=/prefix
> arguments are needed for each.
[Regina Obe]
I would agree there especially since I don't think our --with-foo works all
that well anyway. I still end up having to do
PATH=...
To get all the stuff working in all the test cases.
