[postgis-devel] Using pkg-config for PROJ
Sandro Santilli
strk at kbt.io
Sat Feb 9 13:11:00 PST 2019
On Sat, Feb 09, 2019 at 08:35:44PM +0100, Even Rouault wrote:
> You can just set PKG_CONFIG_PATH to point to your custom
> $(install_prefix)/share/pkgconfig directory
Do typical "./configure && make && make install" rules from
source tarball install those pkgconfig files ?
> And the generated code for PKG_CHECK_MODULES allows to manually set
> environment variables
That's a valid alternative to me, if that's the case
I've no problem with using PKG_CHECK_MODULES (that I can see atm)
--strk;
