[postgis-devel] Using pkg-config for PROJ
Even Rouault even.rouault at spatialys.com
Sat Feb 9 13:20:23 PST 2019
On samedi 9 février 2019 22:11:00 CET Sandro Santilli wrote:
> On Sat, Feb 09, 2019 at 08:35:44PM +0100, Even Rouault wrote:
> > You can just set PKG_CONFIG_PATH to point to your custom
> > $(install_prefix)/share/pkgconfig directory
> Do typical "./configure && make && make install" rules from
> source tarball install those pkgconfig files ?
Sure. Well that's the responsibility of the authors of the said library to
make sure they install it, but that's a two liner in Makefile.am:
pkgconfigdir = $(libdir)/pkgconfig
pkgconfig_DATA = proj.pc
http://www.spatialys.com
