[postgis-devel] Using pkg-config for PROJ
Sandro Santilli strk at kbt.io
Sun Feb 10 05:45:59 PST 2019
On Sat, Feb 09, 2019 at 10:20:23PM +0100, Even Rouault wrote:
> On samedi 9 février 2019 22:11:00 CET Sandro Santilli wrote:
> > On Sat, Feb 09, 2019 at 08:35:44PM +0100, Even Rouault wrote:
> > > You can just set PKG_CONFIG_PATH to point to your custom
> > > $(install_prefix)/share/pkgconfig directory
> > Do typical "./configure && make && make install" rules from
> > source tarball install those pkgconfig files ?
> Sure. Well that's the responsibility of the authors of the said library to
> make sure they install it, but that's a two liner in Makefile.am:
> pkgconfigdir = $(libdir)/pkgconfig
> pkgconfig_DATA = proj.pc
The most important library used by PostGIS (GEOS) currently does
_not_ install pkgconfig file (just saying, would be worth adding it)
--strk;
