[postgis-devel] Postgis 2.4.6 regession tests fails on Solaris
Dechaux Eric CEN (BCQ STIG)
eric.dechaux at gendarmerie.interieur.gouv.fr
Mon Jan 21 05:12:24 PST 2019
Hello,
While running checks on postgis 2.4.6 (also tested with 2.4.6dev) on
Solaris 11.3.26.5.0 for sparcv9 the tests for operators and tickets
fails. The stack is custom build :
PostgreSQL 10.6 on sparc-sun-solaris2.11, compiled by gcc (GCC) 5.4.0,
64-bit
Postgis 2.4.6dev - r17057 - 2019-01-21 12:57:29
scripts 2.4.6dev r17057
GEOS: 3.7.1-CAPI-1.11.1 27a5e771
PROJ: Rel. 5.2.0, September 15th, 2018
The fails checks output :
operators .. failed (diff expected obtained: /tmp/pgis_reg/test_53_diff)
tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_91_diff)
Run tests: 120
Failed: 2
The diff files are :
$ cat test_53_diff
46.OBT: eq3|t
46.EXP: eq3|f
62.OBT: #3777|POINT(0 0)|4
62.EXP: #3777|POINT(0 0)|3
63.OBT: #3777.1|GEOMETRYCOLLECTION EMPTY|1
63.EXP: #3777|POINT(0 1)|1
64.OBT: #3777.1|LINESTRING(0 0,0 1)|1
64.EXP: #3777.1|GEOMETRYCOLLECTION EMPTY|1
65.OBT: #3777.1|POINT EMPTY|1
65.EXP: #3777.1|LINESTRING(0 0,0 1)|1
66.OBT: #3777.1|POINT(0 0)|4
66.EXP: #3777.1|POINT EMPTY|1
67.OBT:
67.EXP: #3777.1|POINT(0 0)|3
68.OBT:
68.EXP: #3777.1|POINT(0 1)|1
$ cat test_91_diff
142.OBT: #1023.a|t
142.EXP: #1023.a|f
143.OBT: #1023.b|f
143.EXP: #1023.b|t
307.OBT: #3709|f
307.EXP: #3709|t
How can I diagnose these errors.
Thanks
Eric
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190121/bdce882d/attachment.txt>
