[postgis-devel] Postgis 2.4.6 regession tests fails on Solaris
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Mon Jan 21 05:33:09 PST 2019
Given the rarity of architecture I suggest you to rebuild with PostGIS 2.5
- we've fixed many things for supporting ARM/MIPS and may happen that your
sparcv9 will just catch up. We didn't have any SPARC for testing and didn't
know of any install on SPARC until today. Please send the patches if you'll
figure them out.
The numbers in front of error messages are ticket numbers, to have a look
what they meant you just browse to them.
https://trac.osgeo.org/postgis/ticket/3777
https://trac.osgeo.org/postgis/ticket/1023
googling for "postgis 1023" also shows MIPS port failure that was abandoned
due to nobody having a MIPS that can replicate the failure, funding or
belief that MIPS is used:
https://trac.osgeo.org/postgis/ticket/4137
On Mon, Jan 21, 2019 at 4:18 PM Dechaux Eric CEN (BCQ STIG) <
eric.dechaux at gendarmerie.interieur.gouv.fr> wrote:
> Hello,
> While running checks on postgis 2.4.6 (also tested with 2.4.6dev) on
> Solaris 11.3.26.5.0 for sparcv9 the tests for operators and tickets
> fails. The stack is custom build :
> PostgreSQL 10.6 on sparc-sun-solaris2.11, compiled by gcc (GCC) 5.4.0,
> 64-bit
> Postgis 2.4.6dev - r17057 - 2019-01-21 12:57:29
> scripts 2.4.6dev r17057
> GEOS: 3.7.1-CAPI-1.11.1 27a5e771
> PROJ: Rel. 5.2.0, September 15th, 2018
> The fails checks output :
> operators .. failed (diff expected obtained: /tmp/pgis_reg/test_53_diff)
> tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_91_diff)
> Run tests: 120
> Failed: 2
> The diff files are :
> $ cat test_53_diff
> 46.OBT: eq3|t
> 46.EXP: eq3|f
> 62.OBT: #3777|POINT(0 0)|4
> 62.EXP: #3777|POINT(0 0)|3
> 63.OBT: #3777.1|GEOMETRYCOLLECTION EMPTY|1
> 63.EXP: #3777|POINT(0 1)|1
> 64.OBT: #3777.1|LINESTRING(0 0,0 1)|1
> 64.EXP: #3777.1|GEOMETRYCOLLECTION EMPTY|1
> 65.OBT: #3777.1|POINT EMPTY|1
> 65.EXP: #3777.1|LINESTRING(0 0,0 1)|1
> 66.OBT: #3777.1|POINT(0 0)|4
> 66.EXP: #3777.1|POINT EMPTY|1
> 67.OBT:
> 67.EXP: #3777.1|POINT(0 0)|3
> 68.OBT:
> 68.EXP: #3777.1|POINT(0 1)|1
> $ cat test_91_diff
> 142.OBT: #1023.a|t
> 142.EXP: #1023.a|f
> 143.OBT: #1023.b|f
> 143.EXP: #1023.b|t
> 307.OBT: #3709|f
> 307.EXP: #3709|t
> How can I diagnose these errors.
> Thanks
> Eric
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190121/fe29a062/attachment.html>
