[postgis-devel] [Internet] Re: Postgis 2.4.6 regession tests fails on Solaris
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Mon Jan 21 06:21:39 PST 2019
Thanks for your advices.
Version 2.3.8 is fine, 2.4.4/5/6 are not. For now I can't use 2.5
because of some ESRI ARCGIS dependences. I will build with x86_64 to
check whether the fails comes from the micro-architecture.
Le 21/01/2019 à 14:33, Darafei "Komяpa" Praliaskouski a écrit :
> Hi,
> Given the rarity of architecture I suggest you to rebuild with PostGIS
> 2.5 - we've fixed many things for supporting ARM/MIPS and may happen
> that your sparcv9 will just catch up. We didn't have any SPARC for
> testing and didn't know of any install on SPARC until today. Please
> send the patches if you'll figure them out.
> The numbers in front of error messages are ticket numbers, to have a
> look what they meant you just browse to them.
> https://trac.osgeo.org/postgis/ticket/3777
> https://trac.osgeo.org/postgis/ticket/1023
> googling for "postgis 1023" also shows MIPS port failure that was
> abandoned due to nobody having a MIPS that can replicate the failure,
> funding or belief that MIPS is used:
> https://trac.osgeo.org/postgis/ticket/4137
> On Mon, Jan 21, 2019 at 4:18 PM Dechaux Eric CEN (BCQ STIG)
> <eric.dechaux at gendarmerie.interieur.gouv.fr
> <mailto:eric..dechaux at gendarmerie.interieur.gouv.fr>> wrote:
>     Hello,
>     While running checks on postgis 2.4.6 (also tested with 2.4.6dev) on
>     Solaris 11.3.26.5.0 for sparcv9 the tests for operators and tickets
>     fails. The stack is custom build :
>     PostgreSQL 10.6 on sparc-sun-solaris2.11, compiled by gcc (GCC)
>     5.4.0,
>     64-bit
>        Postgis 2.4.6dev - r17057 - 2019-01-21 12:57:29
>        scripts 2.4.6dev r17057
>        GEOS: 3.7.1-CAPI-1.11.1 27a5e771
>        PROJ: Rel. 5.2.0, September 15th, 2018
>     The fails checks output :
>       operators .. failed (diff expected obtained:
>     /tmp/pgis_reg/test_53_diff)
>       tickets .. failed (diff expected obtained:
>     /tmp/pgis_reg/test_91_diff)
>     Run tests: 120
>     Failed: 2
>     The diff files are :
>     $ cat test_53_diff
>     46.OBT: eq3|t
>     46.EXP: eq3|f
>     62.OBT: #3777|POINT(0 0)|4
>     62.EXP: #3777|POINT(0 0)|3
>     63.OBT: #3777.1|GEOMETRYCOLLECTION EMPTY|1
>     63.EXP: #3777|POINT(0 1)|1
>     64.OBT: #3777.1|LINESTRING(0 0,0 1)|1
>     64.EXP: #3777.1|GEOMETRYCOLLECTION EMPTY|1
>     65.OBT: #3777.1|POINT EMPTY|1
>     65.EXP: #3777.1|LINESTRING(0 0,0 1)|1
>     66.OBT: #3777.1|POINT(0 0)|4
>     66.EXP: #3777.1|POINT EMPTY|1
>     67.OBT:
>     67.EXP: #3777.1|POINT(0 0)|3
>     68.OBT:
>     68.EXP: #3777.1|POINT(0 1)|1
>     $ cat test_91_diff
>     142.OBT: #1023.a|t
>     142.EXP: #1023.a|f
>     143.OBT: #1023.b|f
>     143.EXP: #1023.b|t
>     307.OBT: #3709|f
>     307.EXP: #3709|t
>     How can I diagnose these errors.
>     Thanks
>     Eric
>     _______________________________________________
>     postgis-devel mailing list
>     postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/postgis-devel
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190121/ddda438c/attachment.txt>
