[postgis-devel] [Internet] Re: Postgis 2.4.6 regession tests fails on Solaris
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Wed Jan 23 08:55:51 PST 2019
Hello,
I have tested with postgis 2.5.1 on SPARC with the same checks failing
among new ones.
I also tested on X86_64 with version 2.3.8, 2.4.6 and 2.5.1. All three
checks are successful. It seems the failures comes from the
micro-architecture. I wonder how can so few checks fails if there is
really a major issue with SPARC.
I also tested with geos 3.6.3 with again the same checks failing on SPARC.
Regards
Eric
Le 21/01/2019 à 15:21, Dechaux Eric CEN (BCQ STIG) a écrit :
> Thanks for your advices.
> Version 2.3.8 is fine, 2.4.4/5/6 are not. For now I can't use 2.5
> because of some ESRI ARCGIS dependences. I will build with x86_64 to
> check whether the fails comes from the micro-architecture.
> Le 21/01/2019 à 14:33, Darafei "Komяpa" Praliaskouski a écrit :
>> Hi,
>> Given the rarity of architecture I suggest you to rebuild with
>> PostGIS 2.5 - we've fixed many things for supporting ARM/MIPS and may
>> happen that your sparcv9 will just catch up. We didn't have any SPARC
>> for testing and didn't know of any install on SPARC until today.
>> Please send the patches if you'll figure them out.
>> The numbers in front of error messages are ticket numbers, to have a
>> look what they meant you just browse to them.
>> https://trac.osgeo.org/postgis/ticket/3777
>> https://trac.osgeo.org/postgis/ticket/1023
>> googling for "postgis 1023" also shows MIPS port failure that was
>> abandoned due to nobody having a MIPS that can replicate the failure,
>> funding or belief that MIPS is used:
>> https://trac.osgeo.org/postgis/ticket/4137
>> On Mon, Jan 21, 2019 at 4:18 PM Dechaux Eric CEN (BCQ STIG)
>> <eric.dechaux at gendarmerie.interieur.gouv.fr
>> <mailto:eric..dechaux at gendarmerie.interieur.gouv.fr>> wrote:
>>     Hello,
>>     While running checks on postgis 2.4.6 (also tested with 2.4.6dev) on
>>     Solaris 11.3.26.5.0 for sparcv9 the tests for operators and tickets
>>     fails. The stack is custom build :
>>     PostgreSQL 10.6 on sparc-sun-solaris2.11, compiled by gcc (GCC)
>>     5.4.0,
>>     64-bit
>>        Postgis 2.4.6dev - r17057 - 2019-01-21 12:57:29
>>        scripts 2.4.6dev r17057
>>        GEOS: 3.7.1-CAPI-1.11.1 27a5e771
>>        PROJ: Rel. 5.2.0, September 15th, 2018
>>     The fails checks output :
>>       operators .. failed (diff expected obtained:
>>     /tmp/pgis_reg/test_53_diff)
>>       tickets .. failed (diff expected obtained:
>>     /tmp/pgis_reg/test_91_diff)
>>     Run tests: 120
>>     Failed: 2
>>     The diff files are :
>>     $ cat test_53_diff
>>     46.OBT: eq3|t
>>     46.EXP: eq3|f
>>     62.OBT: #3777|POINT(0 0)|4
>>     62.EXP: #3777|POINT(0 0)|3
>>     63.OBT: #3777.1|GEOMETRYCOLLECTION EMPTY|1
>>     63.EXP: #3777|POINT(0 1)|1
>>     64.OBT: #3777.1|LINESTRING(0 0,0 1)|1
>>     64.EXP: #3777.1|GEOMETRYCOLLECTION EMPTY|1
>>     65.OBT: #3777.1|POINT EMPTY|1
>>     65.EXP: #3777.1|LINESTRING(0 0,0 1)|1
>>     66.OBT: #3777.1|POINT(0 0)|4
>>     66.EXP: #3777.1|POINT EMPTY|1
>>     67.OBT:
>>     67.EXP: #3777.1|POINT(0 0)|3
>>     68.OBT:
>>     68.EXP: #3777.1|POINT(0 1)|1
>>     $ cat test_91_diff
>>     142.OBT: #1023.a|t
>>     142.EXP: #1023.a|f
>>     143.OBT: #1023.b|f
>>     143.EXP: #1023.b|t
>>     307.OBT: #3709|f
>>     307.EXP: #3709|t
>>     How can I diagnose these errors.
>>     Thanks
>>     --     Eric
>>     _______________________________________________
>>     postgis-devel mailing list
>>     postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/postgis-devel
>> Darafei Praliaskouski
>> Support me: http://patreon.com/komzpa
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190123/6c4902d6/attachment-0001.txt>
