[postgis-devel] Makefile in topology directory
Sandro Santilli strk at kbt.io
Mon Jan 28 00:29:18 PST 2019
On Sun, Jan 27, 2019 at 04:29:27PM -0800, Bruce Rindahl wrote:
> Nothing similar is in the file topology/test/Makefile
> Should it be hard coded or do we just need to state it has to be in your
> PATH?
It must be in your path:
  PSQL=psql
We could have ./configure check for psql to use the same across all
makefiles (not all makefiles want to use PGXS)
> I am not sure how to create a patch since this file is generated by
> configure.
It is generated from Makefile.in so you can use that one.
--strk;
