[postgis-devel] create extension failed with undefined symbol
LIANGBO
18043625 at cnsuning.com
Thu Jul 4 04:45:49 PDT 2019
> The above error comes from libgdal, any attempts to use that library
> would give you the same error. Try gdalinfo for example.
I've tried to use gdalinfo,and the same error occured.
> I think you should report this issue to your red-hat distribution
> packager, or build gdal/postgis yourself.
Thank you for your advice. I'll build gdal/postgis on my environment.
Best Regards,
LIANGBO
Date: 2019-06-27 23:51
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] create extension failed with undefined symbol
On Thu, Jun 27, 2019 at 04:54:07PM +0800, 梁博(18043625) wrote:
> Dear All,
> I'm trying to create postgis extension with version2.5.2,and then the following error occured.
> app_db=# create extension postgis;
> ERROR: could not load library "/usr/pgsql-10/lib/rtpostgis-2.5.so": /usr/gdal23/lib/libgdal.so.20: undefined symbol: ecs_SetReportErrorFunction
> gdal23-libs-2.3.2-7.rhel7.x86_64.rpm
> gdal23-2.3.2-7.rhel7.x86_64.rpm
> gdal23-debuginfo-2.3.2-7.rhel7.x86_64.rpm
--strk;
postgis-devel mailing list
postgis-devel at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190704/40c55224/attachment.html>
