[postgis-devel] jsonb leftovers on upgrade
Bruce Rindahl
bruce.rindahl at gmail.com
Fri Jun 28 14:04:54 PDT 2019
Sounds like a possibility. Lets take this offline and see what I can do.
Thanks
Bruce
On Fri, Jun 28, 2019 at 1:49 PM Regina Obe <lr at pcorp.us> wrote:
> Ø What does it take to set up a bot? I can dedicate a 32 bit Debian
> Buster if you can point me to directions. They are building PG12-dev and
> PostGIS-3dev from source right now.
> Ø Bruce
> Bruce thanks for the offer. We are still in our infancy of bot readiness
> but we’d be happy to have you on our Bot Journey.
> We have a couple of modes going - I can send you instructions off list.
> First I have to make instructions
> Option 1: Easiest – is you register as an osgeo drone agent – this is all
> dockerized so wouldn’t be able to test various permutations of craziness
> you would want to configure and would use one of our docker contains.
> Of course presumes you have docker installed.
> But we could do things such as special upgrade tests on specific agents
> and so forth which is controlled by the dronie yaml file
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/svn-trunk/.drone-1.0.yml
> Option 2: Jenkins slave – this is a bit more involved
> Would require you have your system set to build postgis and regress.
> And then we have different ci scripts for each Jenkins bot – which you can
> see here:
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/svn-trunk/ci
> (all those are Jenkins bots except for Travis )
> On the Jenkins side (Debbie) Jenkins looks up workers (just Bessie and
> bessie32 at moment for FreeBSD) and triggers postgis_regress.sh script in
> the workers folder
> Winnie/Debbie are complete Jenkins server too and do their own tests.
> Winnie in addition to windows regression testing does windows packaging.
> So that’s why you see more scripts there as some are meant for building
> packaging the binaries into a zip file.
> Debbie also does the doc building on the site, so hers is more complicated
> for that reason.
> Hope that helps,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190628/7951aa33/attachment-0001.html>
