[postgis-devel] bots
Bruce Rindahl
bruce.rindahl at gmail.com
Sat Jun 29 12:10:04 PDT 2019
Using the brand new Rasbian that just dropped this week. It is 32 bit and
based on the soon to be released Debian Buster. 64 bit on the raspberry pi
is possible but I didn't see any performance improvement so went back to
stock.
GDAL and GEOS are the latest but PROJ is at 5.2
I have no issues compiling the trunk versions of postgis and postgresql.
I have several raspberry pi's in my cluster setup so I can configure them
however you want.
Looking at your directions, I think the Jenkins set up is a better way to
go as well.
Let me know how to proceed
Thanks
Bruce
On Sat, Jun 29, 2019, 11:56 AM Regina Obe <lr at pcorp.us> wrote:
> Bruce,
> Cc’ing dev list on this as I think other people might have input on this.
> This is really cool. I’m thinking it might be useful not to have this one
> docker based, and we can add this to Jenkins and have it native – that way
> we can test natively how it works in raspberry pi.
> The issue with docker is that it’s hard to test architecture differences
> since it’s environment is whatever the OS is of the docker image. Also we
> haven’t setup a system whereby we can keep our docker images up to date (on
> our TODO), thus we are missing testings such as PostgreSQL 12 head in our
> docker installs.
> That said, let me try to write up some instructions so we can set this as
> a Jenkins bot.
> One question – and might be dumb one since I’ve never worked with
> raspberry pi – is this a 32-bit or 64-bit. Our testing on 32-bit systems
> is very spotty so we often don’t find out about issues until packagers
> complain.
> Thanks,
> Regina
> *From:* Bruce Rindahl [mailto:bruce.rindahl at gmail.com]
> *Sent:* Friday, June 28, 2019 5:35 PM
> *To:* Paragon Corporation <lr at pcorp.us>
> *Subject:* bots
> Regina
> Just to let you know, I am playing with a cluster of raspberry pi's to
> learn not only distributed computing but sharding as well using citus.
> Using Debain buster which has geos 3.7.1, proj 5.2 and gdal 2.4
> I am set up to grab the latest versions of postgresql-12 trunk and
> postgis-3 trunk. Everything seems to be building fine. This is not a
> production database so I can do testing. The things i am testing now
> really aren't using postgis for clustering so if you need different version
> of that I can try. In fact it might be fun to see if different versions
> can work together in a cluster.
> I have never set up docker but I know it is possible on a raspberry
> Bruce
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190629/20479243/attachment.html>
