[postgis-devel] Error on make check
Bruce Rindahl
bruce.rindahl at gmail.com
Thu Mar 7 19:14:23 PST 2019
On revision 17301.
Running make check gave this error at the end:
make -C core check
make[2]: Entering directory '/home/pi/postgis-3.0.0dev/regress/core'
/usr/bin/perl ../run_test.pl ../loader/Point ../loader/PointM
../loader/PointZ ../loader/MultiPoint ../loader/MultiPointM
../loader/MultiPointZ ../loader/Arc ../loader/ArcM ../loader/ArcZ
../loader/Polygon ../loader/PolygonM ../loader/PolygonZ
../loader/TSTPolygon ../loader/TSIPolygon ../loader/TSTIPolygon
../loader/PointWithSchema ../loader/NoTransPoint
../loader/NotReallyMultiPoint ../loader/MultiToSinglePoint
../loader/ReprojectPts ../loader/ReprojectPtsGeog ../loader/Latin1
../loader/Latin1-implicit ../loader/mfile ../dumper/literalsrid
../dumper/realtable affine bestsrid binary boundary chaikin filterm cluster
concave_hull ctors curvetoline dump dumppoints empty estimatedextent
forcecurve geography geometric_median hausdorff in_geohash in_gml in_kml
in_encodedpolyline iscollection legacy long_xact lwgeom_regress measures
minimum_bounding_circle normalize operators orientation out_geometry
out_geography polygonize polyhedralsurface postgis_type_name
quantize_coordinates regress regress_bdpoly regress_buffer_params
regress_gist_index_nd regress_index regress_index_nulls regress_management
regress_selectivity regress_lrs regress_ogc regress_ogc_cover
regress_ogc_prep regress_proj relate remove_repeated_points removepoint
reverse setpoint simplify simplifyvw size snaptogrid split sql-mm-serialize
sql-mm-circularstring sql-mm-compoundcurve sql-mm-curvepoly sql-mm-general
sql-mm-multicurve sql-mm-multisurface swapordinates summary temporal
temporal_knn tickets twkb typmod wkb wkt wmsservers offsetcurve relatematch
isvaliddetail sharedpaths snap node unaryunion clean relate_bnr
delaunaytriangles clipbybox2d subdivide voronoi regress_brin_index
regress_brin_index_3d regress_brin_index_geography minimum_clearance
oriented_envelope frechet in_geojson regress_spgist_index_2d
regress_spgist_index_3d regress_spgist_index_nd
PATH is
/usr/local/pgsql/bin:/usr/local/pgsql/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
Checking for shp2pgsql ... found
Checking for pgsql2shp ... found
TMPDIR is /tmp/pgis_reg
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
failed (Error encountered loading
/home/pi/postgis-3.0.0dev/regress/00-regress-install/share/contrib/postgis/postgis.sql:
/tmp/pgis_reg/regress_log)
Makefile:215: recipe for target 'check' failed
make[2]: *** [check] Error 1
make[2]: Leaving directory '/home/pi/postgis-3.0.0dev/regress/core'
Makefile:28: recipe for target 'check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory '/home/pi/postgis-3.0.0dev/regress'
GNUmakefile:20: recipe for target 'check' failed
make: *** [check] Error 1
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190307/f8bafb9c/attachment.html>
