[postgis-devel] new constrained delauney triangulation
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Mar 11 12:44:37 PDT 2019
On 3/11/19 8:29 PM, Martin Davis wrote:
> This looks impressive.
> I was going to suggest if all that was really needed was polygon
> triangulation then perhaps ear-clipping would be faster. But if this
> is already faster...
> And yes, ear-clipping can produce very ugly triangulations. For an
> approach to solving that see my blog post from a long time back:
> http://lin-ear-th-inking.blogspot.com/2011/04/polygon-triangulation-via-ear-clipping.html
> The risk of crashing hard is a bit of a worry though. Any idea if that
> can be fixed?
Yes it should be possible to prevent. Most cases is just me haven't
added proper handling.
But the most annoying case is when searching the triangles I do it
through the edges who have the triangles on both sides registered.
If there is a bug making the search just switch back and forth between
two triangles it seems unstoppable. Maybe there is some magic code to
put there, but I have had occations when kill pid haven't stopped it.
So I have had to kill the machine or the VM (I am on Qubes so it is easy
in my case).
If it is just switching between 2 triangles it will be easy to put in a
guard checking if that is happening. But if there might be any occasion
when the search travels in a circle jumping over many triangles before
getting back it will be harder.
I cannot see what that situation could be, but there must be some way to
handle also that or it might put a production server in a very bad state.
But I think it is this way of searching that makes it so fast. A lot of
things can be resolved in a very few steps this way.
For instance when checking point in triangle, that function, instead of
returning false (when point is not in the triangle) returns a number
from 1 to 3 telling what edge should be search on the opposite side to
get closer to the point.
So it can very fast do a recursive search and find the point. Since the
points are added in the order of the boundary the next point is seldom
far away, so it is just a few iterations.
> On Mon, Mar 11, 2019 at 11:44 AM Nicklas Avén
> <nicklas.aven at jordogskog.no <mailto:nicklas.aven at jordogskog.no>> wrote:
> I hope Martin also gets the chance to take a look. He managed to
> review my homemade faster distance algorithm almost a decade ago.
> Still glad for that review :-)
> I'll look forward to reviewing this, and reading through the paper.
Thanks! I will try to make it more readable, but it will take a few days
before I get the time.
/Nicklas
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190311/4701033f/attachment.html>
