[postgis-devel] [postgis-users] PostGIS 2.5.2, PostGIS 2.4.7, PostGIS 2.3.9 released
Greg Troxel gdt at lexort.com
Mon Mar 11 17:27:37 PDT 2019
"Regina Obe" <lr at pcorp.us> writes:
> PostGIS Development team is proud to release a patch release for 2.5.2,
> 2.4.7, and 2.3.9
> These are the first stable versions that can compile against the recently
> released Proj 6.0.0
I have updated the pkgsrc package, and tested it against pgsql 9.5.16,
proj 5.2.0, and gdal 2.4.0.  The tests fully pass.
(Earlier, I had tentatively updated gdal from 2.2 to 2.3, but was having
test failures in postgis.  I updated anyway and then to 2.4.0 because of
proj 6, and I'm glad all seems well.)
As I understand it this simply #defines so the deprecated API is
available; understandable as a quick fix.  I gather the real fix is in
trunk (to be 3.0), but I wonder if 2.5 will be EOL by proj 7 in early
2020, given there is still 2.3.
https://github.com/OSGeo/proj.4/wiki/proj.h-adoption-status
