[postgis-devel] regress/00-regress-install/lib/postgis-3.so: undefined symbol: CallerFInfoFunctionCall2
Sandro Santilli
strk at kbt.io
Wed Mar 13 01:07:28 PDT 2019
Current trunk (r17335) fails for me on "make check", with this message:
psql:/usr/src/postgis/repository-sync-scripts/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql:97: ERROR: could not load library "/usr/src/postgis/repository-sync-scripts/postgis/regress/00-regress-install/lib/postgis-3.so": /usr/src/postgis/repository-sync-scripts/postgis/regress/00-regress-install/lib/postgis-3.so: undefined symbol: CallerFInfoFunctionCall2
The problem seems to be that I have dev headers for 10 but am running
tests against 9.6 server. The change in r17336 did not help with this.
--strk;
() Free GIS & Flash consultant/developer
/\ https://strk.kbt.io/services.html
