[postgis-devel] Travis eating Doc errors?
Paul Ramsey
pramsey at cleverelephant.ca
Wed Mar 13 08:21:37 PDT 2019
> On Mar 13, 2019, at 3:12 AM, Raúl Marín Rodríguez <rmrodriguez at carto.com> wrote:
>> Any way to re-serialize output based on thread number, to simplify
>> things ? Or I'd rather have slow-but-readable CI...
> Travis is the only CI where you can get fast results (in 12 minutes you get
> 10 different builds). Let's not ruin that, please.
Concur. This is a corner case, and if Martin had run ‘make check’ before committing (even though it was just doco) he would have seen the error locally. Mostly Travis has been very very good compared to the other bots, which I mostly ignore due to false positives.
P
