[postgis-devel] GeoJSON Precision
Bruce Rindahl
bruce.rindahl at gmail.com
Tue May 7 15:42:02 PDT 2019
Same issue in ST_asText, ST_asWKT, etc. I don't find any other spatial
DB's (mySQL, SAP, etc) using ST_asText even allowing an option for
precision. How is the value of a coordinate stored? Is it different in
say a 64 bit vs a 32 bit windows system?
On Tue, May 7, 2019 at 3:16 PM Martin Davis <mtnclimb at gmail.com> wrote:
> Something to consider is that simply truncating digits can cause
> topological invalidity. So at a minimum there should be a warning about
> this possibility in the doc.
> Ideally this would be part of a wider review of how PostGIS handles
> precision. A more general approach might provide metadata about coordinate
> precision (somewhere), in which case the output functions would just Do The
> Right Thing.
> On Tue, May 7, 2019 at 1:17 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> This blog post reminded me:
>> https://rapidlasso.com/2019/05/06/how-many-decimal-digits-for-storing-longitude-latitude/
>> GeoJSON generation uses DBL_DIG as the number of decimal places, which
>> is… a lot? 15 or 16 depending on your platform. I wonder if maybe we should
>> crank that down to 8 as the default and let people crank it *up* as desired
>> rather than emitting nanometer precision and expecting people to crank it
>> *down* (they don’t).
>> Thoughts?
>> P
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190507/01d83f96/attachment-0001.html>
