[postgis-devel] GeoJSON Precision
Nicklas Avén nicklas.aven at jordogskog.no
Tue May 7 15:52:53 PDT 2019
Martin Davis <mtnclimb at gmail.com> skrev: (8 maj 2019 00:17:57 CEST)
>Something to consider is that simply truncating digits can cause
>topological invalidity.  So at a minimum there should be a warning
>about
>this possibility in the doc.
>Ideally this would be part of a wider review of how PostGIS handles
>precision.  A more general approach might provide metadata about
>coordinate
>precision (somewhere), in which case the output functions would just Do
>The
>Right Thing.
We started to collect some thoughts about those things some years ago
https://trac.osgeo.org/postgis/wiki/ToleranceDiscussion
I think this might also be connected to the idea of offering a precission aware serialization like twkb as an optional format in Postgis. For the accuracy aware user it would give both more compressed data and a more "true" representation of the real world data. Then the precission is built into the serialization as part of the compression.
I have also done tests including triangulation information into twkb (approx 3 bytes per triangle in overhead). That would give a very efficient format for clients to render in gpu? With still smaller size than todays serialization.
That I think would boost qgis rendering quite a lot :).
/Nicklas
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
