[postgis-devel] Recommended GEOS version for PostGIS-3.0.0alpha1 (was: PostGIS 3.0.0alpha1 released)
Sandro Santilli strk at kbt.io
Wed May 29 06:53:06 PDT 2019
On Mon, May 27, 2019 at 10:27:59PM -0400, Regina Obe wrote:
> If the message is not clear to you, you can reword it.
Ok, thanks. Now that I re-read I understood it.
Will try to reword it.
But still.. do we really want to "recommend 3.6 or higher"
if it takes "3.7 or higher to have all features" ? It sounds
like a weird recommendation to do w/out all features ?
--strk;
